oil light
2005 srv 4 wheel
oil light came on pulling into garage/shut car down/check temp gauge normal/check oil ok/
started car light did not come on/did have leaking sensor about two months ago and they replaced it/
will they be able to tell whats going on by the computer/should it have generated an error code
sorry its a honda crv 2005
they is they are a local repair shop
the oil was full and they had replace the sensor two month ago because it was leaking
there has been no oil on floor after the replacement
thanks
thanks
Second, random shop around town isnt qualified to work on a Honda. They probably put and AC Delco filter on and filled it up with Pennzoil.
oil light came on flicker then went off
turn car off then started again oil light did not come back on.
about a month ago took in for oil change and the local honda dealer and they said the oil senor was leaking
should be replaced 150 dollars later got car back.
note dealership has been sold so I am dealing with new staff,the crew I am dealing with are all new I am not sure
I trust them.
Before I spend another 100 dollars to have them diagnosis the problem my question is will the computer show a code to tell them what is going
them what caused it ?
its a 2005 crv and has honda had trouble with oil pumps on this model
thanks
I trust them.
thanks
Your post is confusing. The light didn't come on at all or when you restarted the car? Or did the light come on for a split second, but then remained off during the drive?
Also, it is not clear if you had the dealer replace the oil pressure sensor? If so, does the problem persist to why you want the dealer to re-diagnose it? And no, the computer doesn't data log for the dealer to tell why the oil light came on.
when started again oil light on for split second then stayed off
dealer replaced sensor
did not have problem with oil light before work was done/just the small oil leak they found
and that was about a month ago have not had trouble with oil light before yesterday
did not drive car just restarted it back it out garage in-case it need towed
thanks
thanks
