Y7 to Y8 Intake mani swap.
Old May 22, 2018 | 07:18 AM
Chuck Smith's Avatar
Default Y7 to Y8 Intake mani swap.
So I’m swapping the y7 intake for a y8. I have read up on it and know most of the process such as swapping throttle bodies and what not. Just wondering if anyone knows where to get an IACV block off for the back of the Y8 intake, or is this something that ya to be fabbed?
Old May 23, 2018 | 03:21 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Y7 to Y8 Intake mani swap.
Y7 Motor is from the 96-00 civics. Moved the thread to the 92-00 section as you might get better response here than you will from the machinists that are blueprinting and balancing motors.
I really don't think they spend a whole lot of time concerning themselves with block off plates on an intake for a frankenmotor.
Old May 28, 2018 | 11:01 AM
Melissa52hgc's Avatar
I am going the same swap on my 99 Civic LX automatic. I got the head and intake off of a 98 Civic X automatic with the Y8 in it mine has the y7 or it did. Everyone said that everything would be plug-and-play except for the Vtec solenoid and oil pressure solenoid. I am still pulling an eye a VC code though. The car does have a steady idle is far as I can tell I haven't drove it yet because I have a wheel hub at the bearing shop getting pressed.. I have the p2e ECU and will have to pin in the VTech stuff. My AVC connector has two wires on it and it plugs up but as I said I'm still getting a code anyone know anything about this
Old May 28, 2018 | 11:06 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If you haven't wired vtec yet, I would anticipate a vtec code from a vtec ecu.
Can you provide the code number you are getting?
Old May 28, 2018 | 12:40 PM
P505 . The p2e ecu is not vtec. There's no place to hook up vtec or its oil sensor. I would have thought that since the connector hooked up to the iavc that it would work it? Maybe it's bad itself?
Old May 28, 2018 | 01:41 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Have you checked the OEM parts lists to see if the IACV is the same part number for the Y7 and Y8?
I've seen many times mention of 3 wire versus 2 wire IACV but I do not know the cars this pertains to, but it does give one pause to wonder if the IACV is compatible between the two motors (y7 and Y8).
Old May 28, 2018 | 04:06 PM
tony_2018's Avatar
Fish Twig
you're screwed. You need the automatic from an ex as well
Old May 28, 2018 | 05:37 PM
i have the automatic from the ex. Thats what I'm saying
Old May 28, 2018 | 08:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The EX ECU would be a 37820-P2P-A3X or A5X... not a P2E.
Old May 29, 2018 | 08:25 AM
oh you meant I have to have the wiring harness and ECU out of the e x I thought you meant the intake. So is there a way to make it work with the p2e?
Last edited by TomCat39; May 29, 2018 at 10:50 AM. Reason: grammar correction for clear messaging/query
Old May 29, 2018 | 06:30 PM
tony_2018's Avatar
Fish Twig
No. The automatic transmission is not cross compatible.
Old May 30, 2018 | 08:50 AM
mostwanted_ek's Avatar
your probably better off getting a manifold of an ex auto instead of the ex manual.. the ex auto has the iacv blocked off already.. saves you a bit of time trying to fab that plate up..
Melissa52hgc
May 28, 2018 08:02 AM
Hondakid95
Engine Management and Tuning
Dec 29, 2011 02:00 PM
lorenzookc
May 22, 2011 04:37 PM
kkim
12
Jul 5, 2005 05:41 PM
