1999 f23a1 idle issue
Old May 21, 2018 | 04:19 AM
xShadow1292x's Avatar
Default 1999 f23a1 idle issue
Hello all... 99 accord idle issue.... Cold start or normal running temperature. Car will idle poorly (200-400 rpm) with a/c on. New alternator, main relay and just about everything else that can be replaced without opening the engine. Plugs wires dist battery etc. Had codes for alternator and low voltage plus alt showing open diode. Replaced ALT cleared codes. Nothing showing yet. Car will also idle similarly on cold start with head lights on. Thinking electronic load detector. Anyone have any other ideas?
Old May 21, 2018 | 02:53 PM
almightyfargoth's Avatar
Default Re: 1999 f23a1 idle issue
I had this happen to my 6thgen years ago and it was indeed the load detector. I would get a second opinion from a nearby shop but tell them exactly what you think is going on first. It sounds just like what happened to me.
Old May 21, 2018 | 11:39 PM
3 shops said 3 different things and i wasn't sure which one to trust. Ill go back to #3 and see for sure. Hopefully its just the eld not the entire fuse box like some models are thank you kindly. Lets try it and if it doesn't work I'll be back for more.
Old May 23, 2018 | 03:10 PM
holmesnmanny's Avatar
i don't see an individual part for the eld so it looks like its the entire fuse box
https://www.hondapartscheap.com/auto...gine-room-scat
Kindled Light
32
Mar 1, 2019 06:06 PM
plotomatic
Sep 24, 2016 08:29 AM
bk7794
20
Aug 7, 2016 02:59 PM
New Year Wishes
Feb 25, 2011 11:37 PM
boostcrx89
Jan 13, 2008 07:04 PM
