Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 honda civic
Old May 20, 2018 | 06:21 PM
TaliaDessoye's Avatar
Default 2001 honda civic
I have a 2001 honda civic that has a leak and overheats. What could it be?
Old May 21, 2018 | 04:27 AM
ZeroSix's Avatar
Default Re: 2001 honda civic
This question has been answered many times before. Please use the forum search function.
With that in mind, the first thing to do is stop driving the car. If you haven't done so already, you will blow the head gasket, eventually beyond relatively economical repair. Work on tracking down the leak; there are many ways to accomplish this. Easiest is to just, well, look all around the engine bay with a flashlight. It's a good idea to put the car on jack stands, remove the splash guard, and search from below as well as from above. How much coolant are you losing over a given period of time? Feel free to post some pictures.
If you're still struggling, report back with any new findings and we can suggest more invasive ways to determine the root of your coolant loss.
Old May 21, 2018 | 04:52 AM
jmartinez198's Avatar
If you can not find a leak thn it probalby means you have a blown head gasket this job is about 30-150 for the gasket and the labor might be close to 1,000$
Old May 21, 2018 | 09:06 AM
thisguyaves's Avatar
What *KIND* of leak? How are your coolant levels? When does it overheat? Please give as much info as you can so we can help you
Old May 22, 2018 | 07:53 AM
Odoug Douglas's Avatar
Go through the simple stuff for first like check your thermostat make sure you have coolant and it's no leaks any hoses. If that's all good before you go taking apart the head go to the steps and check and see if the gasket could be leaking. Google how to find out if it's leaking. I had a similar issue and only thing that was wrong was that my radiator was actually clogged
netplaceus
Nov 22, 2020 12:45 AM
tjcletzgo
17
Nov 10, 2011 03:51 PM
john222
22
Jul 31, 2011 06:02 PM
Nicky3
16
Jan 1, 2011 11:16 AM
dapek
Classic Hondas
Dec 20, 2010 08:51 PM
