Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
2014 Accord - Emergency Brake Failure next steps
Old May 20, 2018 | 10:27 AM
csage's Avatar
Default 2014 Accord - Emergency Brake Failure next steps
Hi, I recently got my rear driver side tire changed and the rear drivers side emergency brake is not working well. I'm planning to go to the same shop to have them look at it but it's an hour away. Is there anything else I can do on my own? I've attached two images, one at each side of the brake line. It just looks like it's too long but there's no way to individually change the length. With the brake pulled all the way up (way past normal) the passenger brake works well enough but the driver's side still spins by hand.
View from under the dash. The drivers' side brake line is too long.
View of the other side of the cable. It all looked normal to me
Old May 25, 2018 | 09:04 AM
csage's Avatar
Default Re: 2014 Accord - Emergency Brake Failure next steps
Well, as an update, the tire shop had no clue. Another mechanic has advised that the whole caliper needs to be replaced. It is not properly resetting the position of the E brake line.
Since the brake is actually working well enough (passenger brake works and both wheels turn freely when ebrake is disengaged), I'm going to wait until the next time we change the pads and rotors as well, and then do the whole brake system. Will be due in another 6 months.
Hope this helps someone -
Old May 26, 2018 | 05:46 PM
holmesnmanny's Avatar
take some quality pics or vids of the ebrake assembly
AmatuerHour
Classic Hondas
Oct 15, 2013 03:34 PM
baer13
Suspension & Brakes
Sep 15, 2013 03:16 AM
udm_motorsport
Mar 10, 2004 06:17 AM
