95 del sol dohc need air conditioning badly
Old May 20, 2018 | 05:00 AM
chris oubre's Avatar
Default 1995 Honda del sol vtech dohc air conditioning
What do i need for a.c top to bottom from scratch need asap in Louisiana it is very hot please help
Old May 20, 2018 | 05:43 AM
Megalodong's Avatar
Default Re: 95 del sol dohc need air conditioning badly
Googs is your friend: https://www.google.com/search?num=50....0.o0rMVmJ_DMQ
Old May 20, 2018 | 07:42 AM
Originally Posted by Megalodong
can't spend 1600 on ac the other kits dont come with all lines I've heard d series compressor is better to use for space consumption trying to figure out every piece I need
Old May 20, 2018 | 08:27 AM
thisguyaves's Avatar
Default Re: 1995 Honda del sol vtech dohc air conditioning
>Bigger alternator
>200+ watt inverter
>Window AC unit blowing through the rear window
Or go find another delsol with AC equipped and take the whole thing. It'll be a serious undertaking. evaporator, condesor, compressor, piping, climate controls, in-dash radiator-thingy (why can't I remember the name?) Logic dictates that the AC setup from an EG would work too, but I'm no EG expert.
Old May 20, 2018 | 08:43 AM
Feriohhh's Avatar
5 Year Member
Did your car originally have A/C? If so, what parts are still there?
Yes, you can use the d-series compressor with a B20 CRV compressor bracket.
Old May 20, 2018 | 10:35 AM
mk378's Avatar
$1600 doesn't count as "badly"?
You will need a parts car for the lines, box, wiring, etc. Many of those parts are discontinued by Honda and not available new. Don't try using a generic kit.
Old May 28, 2018 | 10:33 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Pull it off a junkyard vehicle for in the 100-200 range. I've done it 2-3 times already. The exact parts you need are detailed in the install instructions .. which I mention in this thread, which you would have found if you had searched: https://honda-tech.com/forums/honda-...ystem-3142320/
Old May 8, 2019 | 02:32 PM
Promark80's Avatar
I have a question.
I have a 95 honda Del Sol that is a 1.5 L, 5 spd. It does not have air conditioning, I do have A/C components from a 93 Del Sol Si. Will those parts work on my 95 Del Sol, condensor, evaporator, drier, compressor, fan, fan shroud, etc.
Thanks for you feedback.
Old May 8, 2019 | 02:50 PM
deschlong's Avatar
Loved
Community Favorite
^ Yes. Check above links for how-to.
xchikon
Jul 6, 2013 11:11 AM
ooopseyesharted
Mar 19, 2009 11:52 AM
Aodhan
Sep 13, 2007 05:51 PM
nighthawkgsr
Dec 15, 2005 06:35 PM
b18bcivic
May 6, 2004 08:16 PM
