B20b high comp with gsr head, safest way to turbo.
Old May 17, 2018 | 10:35 AM
_Db8_gsr's Avatar
Default B20b high comp with gsr head, safest way to turbo.
I have a b20b high compression motor from HMO with the original GSR vtec head, I'm not looking to do crazy amounts of boost especially because I know with high comp motors it's not the smartest, would we even say it would be safe and possible?
Old May 21, 2018 | 09:51 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: B20b high comp with gsr head, safest way to turbo.
sir............how bout some detail. what is "high" to you?
11.1? could easily do 15lbs if tuned correctly by a competent user.
12.1 must use higher octane. e85. 93+
13.1....race fuel or aint care and tune it.
belive it or not. some super high end boosted motors go way up in cr. 14.1...15...16 ..17
Old May 21, 2018 | 11:24 AM
CandyRedRC46's Avatar
OP is basically saying that he has a b20z block and b18c1 head. AKA a static compression ratio of 10.23:1....
On this build I would say if tuning is done well, all components are healthy and ideally sized, you should be okay at 250-300whp.
At over 300whp, you start running into reliability concerns with those b20 sleeves....
Old May 22, 2018 | 09:23 AM
jdmark1's Avatar
Exactly this. Your B20 was only called high compression when you bought it to compare it against the other B20 import motors. Since there are three different stock compressions for B20s, they call them Low, Mid, and High compression engines. You don't really have a "high compression" engine.
Old May 23, 2018 | 05:48 AM
I like this mark guy lol.
GeneEllis
Sep 5, 2013 03:07 PM
boostedb20ek
Nov 9, 2010 03:46 AM
smcowman
Dec 8, 2008 02:17 PM
quikB18B
Dec 12, 2003 01:15 PM
Halo
Nov 5, 2003 07:32 AM
