Suspension & Brakes Theory, alignment, spring rates....
creak when coming to a slow stop or starting
Old May 17, 2018 | 06:18 AM
Canadian_EF's Avatar
Default creak when coming to a slow stop or starting
Hi there
My 89 civic makes a creak when stopping/starting. It seems to be when the weight shifts to the back once I've stopped. It is not a brake squeal, it sounds suspension related.
Recently replaced: OEM LCA bushings front and rear, upper and lower ball joints, full UCA with bushings, rack end bushing.
I'm using an ESP traction bar with heim joints mounted to the bottom of the control arm.
F&F Type 2 coilovers.
Brakes have all been recently done.
RTA bushings are solid, they've been replaced in the past couple years.
I'm leaning towards the upper shock mounts. Is there a good way to test this?
Looking for some input/feedback so I can troubleshoot before buying parts.
Old May 19, 2018 | 06:09 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: creak when coming to a slow stop or starting
Wedge a peice of wood between the seat and brake pedal to activate the brake.
Have someone push/rock the car back and forth while you look for the noise.
Or use a breaker bar on the axle nut (not lug nut) to rock the car.
Did you replace the ball joints with ones from Honda? Or just aftermarket?
Old May 19, 2018 | 07:01 AM
thisguyaves's Avatar
Take a wheel off, jack or otherwise lift from the LCA on each side, see if you can pinpoint it that way? Just sounds like an old strut somewhere
O RLY
Jun 29, 2008 08:35 PM
ieatrice
Oct 27, 2006 10:33 AM
beav
Jul 6, 2006 09:15 AM
ridestrt
May 18, 2004 09:27 AM
andjb
May 21, 2002 02:52 PM
