What headgasket to use, a6 block with z6 head
Old May 16, 2018 | 03:09 PM
Milanosi99's Avatar
Default What headgasket to use, a6 block with z6 head
I have an a6 block and a z6 head. What headgasket should i use on it.
Old May 16, 2018 | 03:19 PM
Milanosi99's Avatar
Default Re: What headgasket to use, a6 block with z6 head
Sorry if this has been answered before. New here and ive been searching but found no direct answer. Please post a link to the thread if its been discussed.
Old May 17, 2018 | 01:31 PM
24TEN's Avatar
PHANTOM MENACE
Any D-series SOHC 88-00 will work. Really the difference is what you are trying to accomplish. Common sense would be to match it to the head since the water jacket is just an open channel but if you're considering compression then thickness of the gasket is the deciding factor.
Old May 17, 2018 | 01:39 PM
Milanosi99's Avatar
Thank you. I bought an eg coupe and it came with a a6 block and a y7 head. Im pretty sure it has a bad headgasket. My bro in law gave me a z6 head he had and figured it throw it on for vtec. The car came with a chipped p28 and has vtec wires going to the bay. Just wanted to make sure i used the right gasket when i put the new head on. Im going to send the head to a machine shop to get checked and whatnot. Not looking for anything fancy. Its just a daily for my gf.
Old May 17, 2018 | 02:13 PM
24TEN's Avatar
PHANTOM MENACE
If that's the case you can try to play with a compression calculator if you want to get it as close to a stock compression ratio for a Z6 but really any of them should work (I don't think the difference in resulting compression ratios varies so much that it'll make a huge difference). I'd personally try to get one that's MLS vs composite material.
Old May 18, 2018 | 03:28 AM
DaX's Avatar
DaX
Loved
Community Favorite
If you can, have the block's deck checked for flatness and machined if needed as well. I know it's a pain if you're just planning to throw a new head on, but I've had two Hondas where I only replaced the head gasket and had the head checked/machined, and it blew the head gasket again in short order. It ends up costing more, because the head needs to go back to the machine shop and you have to buy another new head gasket. I swore this time that if I'm doing a head gasket, the block's deck is at least being inspected for flatness.
fmax81
Oct 19, 2013 04:22 PM
dc101
Apr 8, 2011 12:42 PM
92superhb
May 2, 2006 05:28 PM
