WHAT AXLE B16 Del Sol Swap? TROUBLE
Old May 16, 2018 | 09:02 AM
ChrizXx's Avatar
Icon5 WHAT AXLE B16 Del Sol Swap? TROUBLE
I know there are forums I've read so much and am still having trouble.
I'm going through axles faster than gas.
I drive a B16 Swapped Del Sol, No power steering (I don't know if this plays a factor) But just changed my axles, one axles boot exploded in 2 weeks and the other did in like 3 or 4 weeks.
My main problem is that regardless if the axle is new, My car ALWAYS Clicks hard af in turns. The most annoying embarrassing problem I've had. Just super sick of it.
Currently: Front Left (Driver): 97 Del Sol VTEC Axle
Front Right (Passenger): 90 Integra LS Axle
I'm just so lost at this point. And over this problem. I just wanna turn like a normal person.
Thanks guys.
Old May 16, 2018 | 09:40 AM
2x0's Avatar
2x0
10 Year Member
Default Re: WHAT AXLE B16 Del Sol Swap? TROUBLE
Some OEM Honda del sol VTEC axles should be an exact fit. How low is your car? What mounts did you use for the swap?
Old May 16, 2018 | 09:42 AM
Feriohhh's Avatar
5 Year Member
Old May 16, 2018 | 05:55 PM
ChrizXx's Avatar
Was having trouble before the drop as well. But Im like at a 2" drop from factory. But IDK what mounts Just paid some mechanic to do it YEARS ago. :/
Old May 17, 2018 | 02:15 AM
2x0's Avatar
2x0
10 Year Member
Post pics of each of the engine mounts
Old May 17, 2018 | 08:29 AM
ChrizXx's Avatar
Dope okay! Will post soon.
Old May 17, 2018 | 08:41 AM
Feriohhh's Avatar
5 Year Member
Cool. That's not too low. Next, check the mounts.
Old May 20, 2018 | 11:44 AM
ChrizXx's Avatar
Back Wall Mount
Top Driver Mount
Figured I send the Bay.
Transmission Mount
Old May 20, 2018 | 11:45 AM
ChrizXx's Avatar
Icon4 Re: WHAT AXLE B16 Del Sol Swap? TROUBLE
Ok mounts are up tell me what you guys think, Didnt know Mounts played a Factor.
Old May 26, 2018 | 04:51 PM
ChrizXx's Avatar
Icon5 Re: WHAT AXLE B16 Del Sol Swap? TROUBLE
Help??
Old May 26, 2018 | 06:11 PM
2x0's Avatar
2x0
10 Year Member
Help??
From what I can tell they look like oem mounts, or at least nothing out of the ordinary.
Next steps if it were mine, would be to check the axle length, and for any interference when inserting the axle into the hub such as ABS ring or dust seal that needs to be removed for the axle to fully insert.
To check the axle length, remove axle nut and fully compress the axle by tapping on the end. The end of the axle should be flush with the hub opening. If it’s recessed into the hole, it may be too short. If it protrudes, it may be too long. You can measure this and determine what the overall length needs to be and might need a different set of axles
The other things I mentioned are pretty self explanatory.
Also if you can, get a pic of the angle your axles sit at compared to level ground.
Old May 27, 2018 | 09:17 AM
ChrizXx's Avatar
Damn okay, Im thinking if it'd be smarter to do all this in the process of changing them again but damn okay. What a **** problem. Thanks so much dude.
Old May 27, 2018 | 09:53 AM
White_EG1's Avatar
Your mounts are fine. What side is busting the most? And when you put the axle in, is it locking into the transmission? Is the snap ring around the axle where it goes in present? I’d get a del sol vtec axle on the passenger. And get the one at autozone with a warranty so atleast you won’t have to keep paying for them.
KyleVA
Feb 17, 2007 07:02 AM
wheelieboy20
Dec 5, 2006 06:59 AM
Jesse51
Sep 22, 2005 01:52 PM
kay_animation
Feb 3, 2003 06:04 PM
