Automatic delsol body harness in manual civic
Old May 15, 2018 | 04:47 PM
Civicministock's Avatar
Default Automatic delsol body harness in manual civic
I have a 95 civic ex manual trans and have a auto 94 del sol body harness are they compatible? with the park bypassed it cranks but I don’t have spark please help
Old May 16, 2018 | 07:18 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Automatic delsol body harness in manual civic
did you wire neutral safety?
should be same as park bypass though. because if no neutral safety switch it shouldn't crank I think
correct dizzy?
Old May 16, 2018 | 10:35 AM
Yea correct dizzy and bypassed the neutral safety it cranks over has power to the coil on both sides (+) and (-) with koeo
Old May 16, 2018 | 10:42 AM
I'm not Rick!
power to coil on both sides but no spark? odd
any chance you can try dif plug wires
you have all your grounds in?...positive?
Old May 16, 2018 | 04:25 PM
Yea all grounds are good with key off I have ground at both terminals and no pulse
eddie422
Mar 17, 2011 05:11 AM
thumper64
Jul 18, 2010 01:09 AM
DelSlowmo
Feb 11, 2010 06:16 PM
VRD^suzie
Jun 30, 2008 08:42 AM
MadCityLude
Aug 1, 2006 07:42 PM
