Question about compression numbers - what to do next.
Old May 14, 2018 | 06:45 PM
stir_fry_boy's Avatar
Default Question about compression numbers - what to do next.
Picked up a 2000 Honda Accord with 129,000 miles. Has a misfire cylinder #1. Compression test showed the following:
cylinder 1 - 50
cylinder 2 - 150
cylinder 3 - 170
cylinder 4 - 170
after adding some SAE 30 oil to cylinder #1 compression is now 120. What does this mean? What’s the diagnosis? Bad rings or bad valves?
Old May 14, 2018 | 07:10 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Question about compression numbers - what to do next.
Usually when adding oil to the chamber if the PSI increases it's usually the rings/cylinder is no longer sealing.
If the valves are not properly seating/sealing they can also contribute to a lower than expected/desired compression. Might want to verify they are properly adjusted and retesting before punting for a new/low mileage engine.
Lower compression on #2 may be indicative of a head gasket issue as well. If the oil gets pushed into the leak that would allow build up of pressure for the test.
Old May 14, 2018 | 07:38 PM
Should I take the time to tear this one apart to visually inspect it before I spend the money on a whole engine?
Old May 14, 2018 | 07:53 PM
MAD_MIKE's Avatar
MM Gruppe B
If you can beg/borrow/steal a borescope to observe if the cylinder walls are scored that would save you time from tearing down the engine.
Did the coolant or oil have any discoloration or seem contaminated?(blown head gasket)
Old May 15, 2018 | 06:27 AM
No mixture of oil in coolant or visa versa
B16.vtec
Sep 12, 2013 06:58 AM
zc89hatch
13
Dec 21, 2008 11:40 AM
Tyteg
May 16, 2007 07:30 AM
imgonnalie2u
Jan 11, 2005 08:05 AM
bleebdat
Oct 8, 2002 03:52 AM
