PLEASE HELP HONDA BOYS!!
Old May 11, 2018 | 09:52 PM
Aaron Aguirre's Avatar
Default PLEASE HELP HONDA BOYS!!
Alright. I have a 93’ civic ex 1.6.
Cut it to the chase. I’m having bogging down issues and the car wants to die while I drive it. I have to push the peddle in a certain spot to get it driavable (doesn’t work for more than 3-4 blocks) and my rpm meter goes nuts all over the place. This issue happened about a week after I took the muffler off to sound like a cool rice cup tuner. I have an aftermarket CAI on it of course.
it Also takes for ever to turn over and start. Hella try’s and I’m having to stab the gas pedal a lot. Eventually I smell gas and it starts. ADD IN* I changed the spark plugs from bisch plats to NGK OE. Still same issue.
Anyways to solve this issue. I need to get to work man. Thanks ahead of time.
Old May 11, 2018 | 11:21 PM
Default Re: PLEASE HELP HONDA BOYS!!
Bump
Old May 12, 2018 | 04:03 AM
civic402lx's Avatar
When was the last full tune up done?
Old May 14, 2018 | 05:41 AM
about a month ago. Basic tune up. New oil. New plugs new wireset.
Old May 14, 2018 | 06:11 AM
civic402lx's Avatar
Check fuel pressure. Will need pressure gauge.
Old May 14, 2018 | 07:58 AM
DumpdEJ6's Avatar
I like the tuna here
With your RPM gauge going haywire it sounds more like something grounding out in your harness. How long have you driven the car and it worked fine before doing the exhaust work?
Old May 14, 2018 | 08:28 AM
White_EG1's Avatar
Rpm everywhere sounds like a bad igniter
Old May 14, 2018 | 11:22 AM
tony_2018's Avatar
Fish Twig
This
Old May 14, 2018 | 08:23 PM
everything was was fine before the exhaust came off. Made me think it’s an airflow problem. FOUNDOUT RHE ORHER DAY THAT IF I SORAY START FLUID INTO THE ENGINE FROM THE INTAKE HOLE IT STARTS RIGHT UP.
Old May 15, 2018 | 06:15 AM
DumpdEJ6's Avatar
It seems pretty unlikely that anything related to the exhaust could make your car do this, unless you messed up a fuel line or something under the car.
keslerbuilt
Oct 23, 2013 04:16 PM
Moaltar
Honda Civic (2001 - 2005)
Oct 17, 2013 11:39 AM
04Civic_HFP
Engine Management and Tuning
Dec 23, 2009 05:31 AM
KRE8TIVE
Apr 10, 2009 12:48 PM
hawjboi
17
Nov 11, 2008 08:56 AM
