Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Easy Alternator Question
Old May 11, 2018 | 03:41 AM
kaivorth's Avatar
Default Easy Alternator Question
Idle will sometimes drop to 12.2v, load the alternator will go from 13.8-14.0
Is it time for a new alternator? If so what's a good brand one? This one was an AutoZone one.
Headlights were getting so dim (nice LED ones) so i bought a cigarette lighter voltage indicator to aid in diagnosing
Old May 11, 2018 | 10:47 AM
thisguyaves's Avatar
Default Re: Easy Alternator Question
If it bothers you, try a new one. A cheap fix would be to clean your grounds, it might help. Cigarette lighter voltage meters aren't super accurate either, BTW, they usually read about 0.2-0.4 low.
Old May 11, 2018 | 02:12 PM
Zigory's Avatar
I have the same issue, post an update if you don't mind if you end up solving it.
Old May 11, 2018 | 03:31 PM
Using my cigarette lighter voltage meter, my power is all over the place, often 11.9 at idle, 13.9 at most during driving, and occasionally drops to 11.9 while driving. I know my alternator is to blame, but I have had zero issues starting or running my lights/subs other than the headlights dimming slightly. I'm not saying it's a good idea, but I've been running it like this for months with no issues... So your problem is probably not as serious as you might think.
Old May 11, 2018 | 03:33 PM
Zigory's Avatar
Yeah, I've been running it for a couple weeks now. I'm not too worried because the last time my alternator failed my headlights started to flicker as well as my interior dome lights so I think that might be a better warning sign.
Old May 11, 2018 | 04:11 PM
Just keep an eye on it and have a replacement or the cash for one set aside. Might also check you ELD... should be changed every few years
Old May 12, 2018 | 03:05 AM
holmesnmanny's Avatar
when not loaded, Honda alternators will usually charge in low output mode to save gas, which is 12.60 .....until you go over 45mph or when you add some load it will charge in full output which is around 14.6ish
Old May 12, 2018 | 04:42 AM
ZeroSix's Avatar
Have a multimeter? You can check the entire charging system easily.
If you decide to replace the alternator, I strongly encourage avoiding re-manufactured or off brand parts, as their quality is often hit or miss. LKQ has a well stocked and frequently updated online directory; I was able to source a low mileage OEM alternator for 60 dollars shipped.
Old May 13, 2018 | 09:28 AM
kaivorth's Avatar
Didn't expect lots of replies.
This is as serious as I think it is. My headlights get so dim, I CANNOT see at times.
Interesting update, using the cig lighter meter, if I leave the AC or heat on, it goes right back to 13.4v, and I tested my headlights out, and I've never seen them so bright before. I know I have an issue.
I'm suspecting a ground now, just ordered some 4GA cable, and I plan on directly grounding my alternator to my battery neg. Will post back in about a week when I try it.
Old May 13, 2018 | 01:59 PM
your problem is that junk Autozone alternator
Old May 14, 2018 | 05:16 AM
kaivorth's Avatar
I will source an OE alternator if the grounding isn't an issue and try that next
Old May 14, 2018 | 06:20 AM
Well, you described the issue well so a lot of people are willing to help. My issue is similar, just headlights on it's kinda dim, but not to the point of not seeing... turning on fogs or AC will kick the voltage up instantly for me too. If you can't see, take action lol. Let me know what fixes it
Old May 22, 2018 | 04:44 AM
kaivorth's Avatar
I do have a multimeter, what's the easiest way to test the charging system with a multimeter?
Also, where do I attach the ground to the alternator? I see a nut that looks like it would be it, it do I attach it to the bracket it's on?
Old May 22, 2018 | 06:29 AM
NDNV's Avatar
Did you have an issue with the halogen headlight bulbs dimming before installing the LED ones? LED draw less current.
Old May 22, 2018 | 08:04 AM
ZeroSix's Avatar
EricTheCarGuy has a great step by step video on troubleshooting your charging system:
Old May 27, 2018 | 04:01 PM
kaivorth's Avatar
I'll continue to update this with a fix if I ever get there.
Just watched the video on testing an alternativ, bad news is since I'm by myself, I can't take the multimeter and check voltages while revving the car. I need clamps or something at the least
Might just throw in a used alternator and cross my fingers..
Old May 27, 2018 | 06:13 PM
lol some people just wanna make things more difficult than they are
J(ef)F
Apr 1, 2015 10:40 AM
realred96
Classic Hondas
May 11, 2011 03:45 PM
Layziebtnh055
May 3, 2004 03:15 AM
B2AMMO
Mar 9, 2004 07:59 AM
