2004 ep3 sir brake upgrade
Old May 8, 2018 | 05:28 AM
WORDLUNCH's Avatar
Default 2004 ep3 sir brake upgrade
I want to do an upgrade but dont want to change axles and such what is the best route to take ? I juat want direct bolt up no hassles and jimmy rigging?
Old May 8, 2018 | 02:24 PM
thisguyaves's Avatar
Default Re: 2004 ep3 sir brake upgrade
Easiest way: Stoptech. https://www.corsportusa.com/i-210-20...kit-front.html
Integra type R brembos if you're serious about it, or RSX typeS for bigger front rotors. Both will require at least new axles, having different count splines on the hub iirc.
Old May 8, 2018 | 02:45 PM
WORDLUNCH's Avatar
Old May 8, 2018 | 03:32 PM
You just quoted yourself, sir.
Stoptech package includes discs, 4 piston calipers, and adapter brackets. No other changes, such as axles. $1800.
Old May 8, 2018 | 05:42 PM
tommycrx's Avatar
That link is for the wrong EP3s, btw.
The title iz confusing - do you have a type R and want to upgrade the brakes or want to upgrade the brakes to possibly the type Rs?
If you don’t want any hassles and have normal 04 ep3 brakes, just upgrade to the RSX Type S rotors and calipers, ss brake lines, good pads, and new fluid.
No no need for new axles.
Old May 9, 2018 | 06:44 AM
Ah, yeah, typeS would drop right on. I had it in my mind that he had the 4 lug EP3 for some reason...
Old May 9, 2018 | 11:51 AM
WORDLUNCH's Avatar
Thank you I have a 2004 ep3 sir it's a Canadian model yes exactly the info I was looking for I have 5 bolt axles allready as the 2004-5 came factory this way but yes All.I am looking to do is swap all brakes rotors pads calipers with direct bolt on Honda/Acura parts no mess no fuss just solid upgrade !!
Old May 9, 2018 | 02:15 PM
WORDLUNCH's Avatar
Ok so 2004 ep3 sir for sure is all type s brake rotors calipets and pads ?
Old May 11, 2018 | 06:24 AM
tommycrx's Avatar
No real need to swap to anything for the rears, unless you want to have larger rotors/calipers for appearance sake. I have the Type S brakes on my fronts, and they fit fine on stock rims (my winter setup), if you were concerned about that too.
civicboost89
Honda Civic (2001 - 2005)
Sep 29, 2008 08:52 PM
jdm_DC2R
13
Nov 20, 2005 06:27 PM
HapaHaole
Sep 15, 2004 11:23 AM
HapaHaole
Jun 24, 2004 04:01 PM
GDM Z28
28
Feb 20, 2004 06:26 AM
