01 integra GS-R dies when I hit the accelerater
Old May 5, 2018 | 03:07 PM
POSonda's Avatar
5 Year Member
Icon5 01 integra GS-R dies when I hit the accelerater
Hey guys there's something odd going on with my Integra. So when I hit the accelerator when I'm parked or if I'm just starting to go into first or second gear it kills the car. Or it won't let me accelerate at all or if it does its weak and struggling jumping up in Rpms. If I'm driving at low Speeds it will start to buck unless I speed up. The only time I have no issues is when I'm cruising at speeds above 30 mph. Now this happens once in a blue moon too. I've noticed that if it rains the day prior or the same day that's when it starts acting like this. Another thing I noticed is it happens around the time i fill up with gas. But who knows, these are just some things that came into mind as i'm trying to figure out what is actually going on here. Anyone else have something similar happen to them? I would greatly appreciate anyone's input .
Thank you.
Old May 9, 2018 | 09:59 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: 01 integra GS-R dies when I hit the accelerater
a sensor is getting wet. TPS does this. check the gasket on the TPS and Map sensors.
spray water on each when its running....
Old May 9, 2018 | 08:11 PM
Lord Orange's Avatar
Thank you.
any check engine lights?
Old May 21, 2018 | 10:01 PM
Rome069's Avatar
Check your throttle cable. I have the same issue currently Bc my engine came with a different manifold without the throttle body cable bracket that’s hold the cable to the manifold in place, Once i find a gsr bracket to mount the cable I’m understanding that will stop the same problem that i am having
Old May 23, 2018 | 05:03 PM
POSonda's Avatar
5 Year Member
No, no check engine lights what so ever.
Old May 23, 2018 | 05:05 PM
POSonda's Avatar
5 Year Member
Hm interesting. I'll have a look when I get out of work. What exactly should I be looking for when inspecting the cable?
Old May 23, 2018 | 05:06 PM
POSonda's Avatar
5 Year Member
OK ill give that a try. Thanks for the reply.
WGFletch4WS
Apr 7, 2008 05:39 PM
R6E6I6D
Nov 22, 2005 06:48 AM
GSRontheBottle
Nov 20, 2003 07:34 PM
