1998 civic b16a2 swap
Old May 4, 2018 | 09:35 AM
Civicdave88's Avatar
Default 1998 civic b16a2 swap
So I did The swap into my car from The stock Motor to A B16A2 And I cannot figure out why vTech is not working When I am in gear it feels like it does not have power at all i have chipped p28 ecu also please someone help me troubleshoot this issue
Old May 4, 2018 | 09:45 AM
tony_2018's Avatar
Fish Twig
Default Re: 1998 civic b16a2 swap
b16...torqueless
Old May 4, 2018 | 09:47 AM
Originally Posted by tony_2018
b16...torqueless
what do u mean tony
Old May 4, 2018 | 02:34 PM
tony_2018's Avatar
Fish Twig
How did you verify vtech wasn't working?
Old May 4, 2018 | 04:04 PM
HondaPartsHero's Avatar
Technical Hero
Year, make, model, any check engine lights?
Old May 4, 2018 | 04:26 PM
Ok so it's a 1998 Honda civic hx with a b16a2 swap it has check engine light but it has no power like I have it in 3rd gear it' really quiet and it only is doing 45 top out speed something is wrong I can' took it up for some reason foot won't read on the obd reader..
Old May 6, 2018 | 03:18 AM
Technical Hero
You’ll have to pull the codes the old fashion way (look in the FAQ above), the reader won’t work on an obd1 ECU. Then post the codes
Old May 15, 2018 | 01:00 PM
xcrman's Avatar
Hello CivicDave,
I hope you got your issues sorted out and I hope you don't mind me hijacking your thread. New here...so not sure about that stuff.
I jumped on the forum looking for some info on a planned CRX B16a2 swap and have a few questions about the axle shafts and transmission.
What I'm starting with:
89 Honda CRX Si -
D16a6 motor
Syncrotech rebuilt transmission with LSD, upgraded synchros, 4.9 FD and cable clutch (Y1 series - I think)
ProCivic axle shafts level 2.9
OBD1 conversion completed
Road course use only - no on-highway use
Where I am going:
Put the B16a2 motor in the CRX
Mount my transmission from D series to B-series motor
Keep OBD1.
Thinking the 4.9 FD in my transmission should allow 130MPH in 5th gear at 8000 RPM - hoping the pulls are not too short getting to that speed.
My questions about swap:
Is a 90-91 Integra clutch required to mount the Y1 transmission to a B16a6 motor?
If I'm using the Y1 transmission, can I use my high-performance axle shafts? I'm not sure what my options are here?
I see lots of info out there on other details like engine mounts and VTEC wiring and so I think I'm all set in those departments.
Thanks!
Darryl
Old May 16, 2018 | 09:19 AM
xcrman's Avatar
I bet my last post had some eyes rolling ....
I just found this thread and my plan is falling apart. States a D-series transmission cannot be used in a B-series motor without some form of an adapter plate.
https://honda-tech.com/forums/honda-...ranny-2841229/
The error in my research was due to me thinking the current transmissions on the D16a6 was an Y1 . The actual transmission on my D-series is a LS3 , so it's not gonna fit on my D16a6 motor.
I will have to use the transmission that came with the B16a2 motor and see whats involved in connecting my clutch cable to a hydraulic transmission or do some research on the adapter plate.
I'll figure it out..sooner or later.
Philly_birds58
Mar 22, 2016 12:24 PM
Civicthusiast
27
Feb 25, 2009 07:36 PM
