oil in old ac compresser
Old May 2, 2018 | 08:11 PM
cliffbrown's Avatar
Default oil in old ac compresser
honda civic 1999 trs090 ac compressor. If i drain oil from old compressor how much should i get out. I was told i should get 60% of what is sapost to be in system.
Old May 3, 2018 | 12:33 AM
holmesnmanny's Avatar
Default Re: oil in old ac compresser
however much you get out, you use the same amount in the new compressor, usually new compressors will come pre-oiled, densos will be good to go already, most other aftermarkets you have to drain and put back in the same amount you took out of the old, but use the new oil, not the old oil
Zebra
Honda Civic (2006 - 2015)
Feb 8, 2018 08:21 PM
flanker
Mar 7, 2016 12:45 AM
Rick1t
May 6, 2013 06:03 PM
AndyD
Apr 25, 2005 10:17 AM
