Honda CR-V & Element 2WD & 4WD Element & CR-V
2016 CRV Turn Signal Fuse
Old May 2, 2018 | 07:10 AM
rlh781's Avatar
Default 2016 CRV Turn Signal Fuse
For the past couple weeks our touring 2016 CRV has been blowing the turn signal fuse. There has been no apparent cause for this to happen. Honda dealer service looked at it for over a day and determined a bad cell in the battery was causing the fuse to blow. The battery was replaced last week but the fuse continues to blow. I'm taking the car back into the dealer again tonight but looking for suggestions on what might be causing this problem other then a bad battery. As mentioned the fuse does not immediately blow during turnsignal use (either left or right) but appears to blow during normal driving. The first appearance that the fuse has blown once again is when we try to use the turnsignal and nothing happens. After replacing the fuse the signals appear to work properly for a day or so.
dhealey
11
Jun 5, 2024 06:31 PM
niceprelude
Sep 2, 2011 06:58 AM
george34
Audio / Security / Video
32
Aug 17, 2006 12:47 PM
crx1856
Aug 17, 2003 04:28 PM
ModlesSI
Feb 22, 2003 03:16 PM
