Suspension & Brakes Theory, alignment, spring rates....
Spoon twinblocks with mg rotors
Old May 1, 2018 | 05:14 PM
CroSi's Avatar
Default Spoon twinblocks with mg rotors
Can anybody here tell me if Spoon twinblock calipers will work with MG ZS 180 rotors? They are 282mm in diameter and 25mm wide.
Old May 3, 2018 | 04:53 PM
KoRn_vIRuZ's Avatar
Default Re: Spoon twinblocks with mg rotors
Yes they will. I just had to use some narrow precision washers to center the disc perfectly. 0.5 mm wide IIRC.
Old May 4, 2018 | 07:17 AM
CroSi's Avatar
Sent you a PM check inbox!
Old May 6, 2018 | 03:46 PM
KoRn_vIRuZ's Avatar
Just to add for others that may find this thread: depending on the thickness of the brake pads you might need to shave them slightly. After installation on an EG6, there are 17.5 mm between the caliper and the rotor.
EKRon
Jul 10, 2007 06:07 PM
Kavehman
Mar 16, 2007 06:15 PM
shinchan
Mar 27, 2003 11:12 AM
AllMotorITR
Jan 22, 2002 08:35 PM
