2002 accord NO ac clutch/condensor fan
Old Apr 26, 2018 | 06:02 AM
rahu's Avatar
Default 2002 accord NO ac clutch/condensor fan
I press the ac button on the panel. It lights up green but ac clutch and condensor fan are not coming on. The cooling fan comes on at 205 f.
So that seems to be working. Swapped relays still no ac or condensor fan.
What controls both the condensor fan and ac clutch. Can one operate without the other?
Is there a ac pressure transducer and where is it located?
Does it require to evacuate the system to change it?
​​​​​​​Thanks this is my first post.
Old Apr 27, 2018 | 06:08 AM
rahu's Avatar
Default Re: 2002 accord NO ac clutch/condensor fan
Update: I bought an add freon kit from walmart and hooked it up to the low port. Sure enough after a few seconds the ac clutch and condenser fan both kicked in. It was low on freon.
So it appears the condensor fan and ac compressor are activated together by the ecu.
​​​​​​​I am happy i did not have to mess with the ac pressure transducer.
Old Apr 29, 2018 | 08:50 AM
rahu's Avatar
Update: i bought a freon topping kit at walmart and attached it the low port. It automatically turned on the ac compressor and condensor fan. So that was great. I did not have to jump the compressor.
Apparently the pressure transducer sends a signal to ecu and only then does the condensor fan come on.
Old Apr 29, 2018 | 08:22 PM
holmesnmanny's Avatar
it would be best to add some uv dye
Old Apr 30, 2018 | 10:27 AM
MyAcc0rd's Avatar
^^^ this. That'll temp fix it, but it's not gonna solve your problem if it's leaking out of your system somewhere...
Single-Cam
16
Feb 10, 2016 07:23 PM
knotcher
Jun 29, 2015 10:34 AM
94_civicEx
Honda Civic (2006 - 2015)
Jun 13, 2014 12:28 AM
old man honda
Apr 14, 2006 07:01 AM
