Ep3 chassis dc5 subframe?
Old Apr 22, 2018 | 06:23 AM
honda_12V's Avatar
Default Ep3 chassis dc5 subframe?
Hey everyone.
I have a ep3 with the d15 engine.
Looking to go k swap. Can I use a dc5 subframe will it fit??
Regards
Old Apr 22, 2018 | 08:47 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Ep3 chassis dc5 subframe?
Yes, the subframe bolts right up. You will need the lower A-arms as well.
Old Apr 23, 2018 | 04:47 PM
toyomatt84's Avatar
Sanji
The LCA's are the same, though. You don't necessarily need them.
Old Apr 24, 2018 | 10:11 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If you are referring to the USDM EP3, I completely agree with you. However, the OP states that he has a D15 engine in the said EP3 (this combination is not found in the US market), so I would assume that this means that the subframe/cradle and lower A-arms are more like those that are found on a USDM D17 SOHC Civic Coupe or Sedan. These part numbers differ from the RSX (DC5) lower control (A-arms)... are they still interchangeable ??? What is different about them ???
Old Apr 25, 2018 | 07:20 PM
toyomatt84's Avatar
Sanji
The only real difference between them is the knuckle that attaches to them. The IT-R LCA's are different, due to being aluminum and having a slightly different ball joint seat, but that's not a US-based item either.
k20a_joe
Aug 11, 2015 07:35 AM
RED_90TEG
Dec 10, 2009 11:41 AM
CR91X
26
Jul 21, 2007 12:46 PM
PIntegraMP
Apr 9, 2006 02:25 PM
yagotrice
May 11, 2005 06:53 AM
