1992 Accord Oil Leak
Old Apr 21, 2018 | 05:42 PM
Mveilenstein's Avatar
Icon5 1992 Accord Oil Leak
When I bought my 92 Accord almost four months ago, it had a leaking rear main seal (still does - I'm not concerned about that right now). It has always leaked a little bit of oil, but today, after sitting in my garage for over 24 hours, I found a fresh oil leak on the floor. I know the leak could have happened while the engine was warm yesterday, but I don't see anything obvious at first glance. I do know that the valve cover gasket was replaced in December, but is it possible that it could have failed already?
Old Apr 21, 2018 | 07:24 PM
97accordex2.2's Avatar
Default Re: 1992 Accord Oil Leak
where abouts under the car was it leaking
Old Apr 21, 2018 | 07:53 PM
The leak looks to be coming from the front of the engine.
Old Apr 21, 2018 | 07:55 PM
could be oilpan gasket
Old Apr 21, 2018 | 07:56 PM
Turbo1983's Avatar
Could be coming from a # of places, oil filter not tighten properly, oil breather, main seal or heck even the dizzy seal leaking on tranny an running to bottom or could be other thing really would be helpful of oil spot location while car is parked
Old Apr 21, 2018 | 08:00 PM
What I can see right now are two spots on the ground near the front center of the engine and oil on the bottom of the engine. I haven't investigated further but will be in the morning.
Old Apr 21, 2018 | 08:05 PM
Turbo1983's Avatar
Hummm sounds like the oil pan gasket like the guy above said. When was last time you changed it? If you have already changed it, did u tighten bolts an few nutz down to spec?
Old Apr 22, 2018 | 05:25 AM
As far as I'm concerned, it's never been changed. I'm going to get under it today and take a look. If that's what it is, I'll replace it and change the oil, since it's due next month anyway.
i will update this thread once I find the problem.
dcarson90
Jan 4, 2018 04:37 PM
relentlesstech
Jun 22, 2016 11:18 AM
swertepinoy
Feb 27, 2010 10:55 PM
diyguy13
Mar 12, 2009 05:55 AM
wengejor
Feb 10, 2009 10:12 AM
