1999 Integra LS non-vtec 1.8L DOHC fuel issues
Old Apr 18, 2018 | 07:42 AM
KingBiz10's Avatar
Default 1999 Integra LS non-vtec 1.8L DOHC fuel issues
Just bought car still closing the initial can of worms from a purchase. I have a crank but no start issue. I checked my fuel pressure and I'm getting nothing to my filter. Brand new pump. My relay looks almost brand new. Small minute amount of cracking on the terminal for the ground but again it's very minimal. Are there any other possible causes for this. Also didn't start even with starting fluid. Is this a fuel and spark combo issue? Any other advice? Only ObD2 code is p1457 which I believe is the canister solenoid. Or purge valve sensor.
Old Apr 19, 2018 | 01:09 PM
egsleepercivic's Avatar
Default Re: 1999 Integra LS non-vtec 1.8L DOHC fuel issues
do you hear the fuel pump prime or does the check engine light stay on ? it should go off once the pump primes.
you can also check for voltage at the pump
everything you stated says relay to me, you can remove the relay, then remove the
Old Apr 19, 2018 | 01:47 PM
KingBiz10's Avatar
I can hear it prime, I removed the relay and it looks brand new. Only a small small minimal amount of corrosion on the ground (2) terminal. Now I tested my plug wires and two of them are bad. But I still can't understand why I'm not getting fuel to my filter. Could it be clogged preventing flow to the engine and causing it not to fire?
Old Apr 19, 2018 | 03:11 PM
fuel filter is not very expensive, would not hurt to replace especially if you don't know when the last time it was changed
you could also disconnect the line from the fuel filter and see if gas comes out, have some rags or a soda can ready, the bottom line is where the fuel comes into the filter
Old Apr 19, 2018 | 04:43 PM
KingBiz10's Avatar
Awesome thank you very much. I'll update once I've tooled with it a bit.
tjm6
20
Aug 2, 2013 02:33 PM
ghettoda9
Apr 13, 2011 10:03 AM
Pr0ject93hb
13
Mar 21, 2007 09:39 AM
5litereater
Apr 19, 2005 06:20 PM
JDMlyfestyle
25
Oct 16, 2004 11:05 AM
