Suspension & Brakes Theory, alignment, spring rates....
Brake pedal pulsating - ABS bleed needed?
Old Apr 13, 2018 | 11:20 AM
B20Zer's Avatar
Default Brake pedal pulsating - ABS bleed needed?
I've had issues with the brake thudder/pulsating brake pedal on my gen 1 CRV, the driver side brake was also running hotter than the passenger side. I started with the discs and callipers, got the discs skimmed, callipers thoroughly inspected - perfect no signs of seize and slides still well lubed and smooth, put it all back together, no difference at all.
Then I took out the 40a ABS motor fuse and tested the braking without ABS, still the same, one thing I did notice was under extreme braking the passenger side brake was locking up/skidding but the drivers side wasn't.
Then it occurred to me that one brake running hotter than the other probably wasn't a sign or seized calliper or pad drag but rather that the drivers side brake wasn't working very much.
I have read before that sometimes there can be air in the abs system and that causes the brake to grab/fade/grab/fade and create the pulsating brake pedal feel even under light braking.
Has anyone heard of this before or know what else I can try?
GOOKY4U
Honda Civic (2006 - 2015)
11
Nov 12, 2015 04:13 AM
LordAphotic
May 31, 2011 06:06 AM
GotGSR
Apr 19, 2004 04:48 PM
EH2DX
Sep 9, 2002 09:37 AM
