H22 swaped 92 si won't start. Cooling fan comes on and stays on.
Old Apr 11, 2018 | 09:59 PM
preludebeast94's Avatar
Default H22 swaped 92 si won't start. Cooling fan comes on and stays on.
Hi, I have a 92 si with jdm h22 swap. Engine wont start and cooling fan comes on when key is in acc. I have spark at the coil (external coil) and fuel to the rail. No spark from the distributor. Has a new distributor. I've been wire tucking and cut all the abs connectors off problem started right after. Can't find any blown fuses or frayed wires. I'm thinking of pulling the whole harness as I want to relocate the fuse box under the dash. Please help.
Old Apr 11, 2018 | 10:46 PM
holmesnmanny's Avatar
Default Re: H22 swaped 92 si won't start. Cooling fan comes on and stays on.
you swapped the connectors for fan switch and something else
redbull99
16
May 18, 2016 09:46 AM
ngoldsmith1@gmail.com
Honda Civic (2001 - 2005)
Nov 27, 2008 01:36 PM
antballs420
Sep 24, 2005 10:12 AM
bb4mark
Jul 29, 2005 01:55 PM
Six2Six
Jun 23, 2002 10:26 PM
