Oil leak to the right of the oil pan, directly under a white piece
Old Apr 10, 2018 | 01:01 PM
fminusmic's Avatar
Default Oil leak to the right of the oil pan, directly under a white piece
I have a small yet annoying oil leak to the right of the oil pan where there is a white piece and a belt that runs through it. I am not sure what the name of it is, but oil slowly drips from the bottom of the white piece onto the floor.
Any ideas on what it is?
solved, thank you for the help!
Old Apr 10, 2018 | 01:35 PM
Tyson's Avatar
Default Re: Oil leak to the right of the oil pan, directly under a white piece
the crank seal is leaking.
https://estore.honda.com/honda/parts...n=&b=E++13&dl=
Old Apr 10, 2018 | 02:14 PM
fminusmic's Avatar
Originally Posted by Tyson
Thank you!
Old Apr 10, 2018 | 10:10 PM
Marcos Barrios's Avatar
could also be the cam seal
the white thing your talking about is the timing belt cover
once you remove it youll see where its leaking from
top=cam seal
bottom =crank seal
Old Apr 11, 2018 | 06:40 AM
Ol Mans 91 LX's Avatar
Be careful also when/if you remove the crank pulley/harmonic balancer to do this job as they are a bear to find an
OEM replacement for if you have a vehicle made before 92.........................
Old Apr 12, 2018 | 07:20 AM
scelestus's Avatar
If you do have to replace that pulley don't bother finding one for the car (91 LX is right, it's no fun). A pulley from the D15B7 (non-SI/EX engine for a 92-95) works perfectly on the D15B2 I assume you have. Has an extra rib for the alternator that's just dead space on the EF pulley, keep the alternator belt toward the engine and you'll be fine.
Honda-Tree
Honda CR-V & Element
Apr 16, 2014 06:37 AM
JDMjdawg
Sep 28, 2013 06:06 AM
oldskoolDA6
Nov 26, 2007 02:17 PM
ludelvr
Dec 19, 2003 11:01 AM
serious
Nov 4, 2002 05:18 AM
