Idle problem/ Downshift issue
Old Apr 10, 2018 | 12:48 PM
mannyquestions9's Avatar
Default Idle problem/ Downshift issue
When the car is warmed up, or idling at a stop, it bogs all the way down and would stall sometime. No CEL, and everything else is running normal
Old Apr 10, 2018 | 03:56 PM
LuckyStrike90's Avatar
Default Re: Idle problem/ Downshift issue
Most likely your IACV, check wires to sensor and take off and clean any crap out of the valve.
Old Apr 11, 2018 | 06:37 AM
Ol Mans 91 LX's Avatar
I would definitely check what Lucky said first as it is the more common problem. Have you tried to set the idle w/the IAC disconnected?
Is this all the time or just coming to a stop, or.....?
Old Sep 29, 2024 | 09:15 AM
BeKind2YaMind's Avatar
I'm getting the same issues on a 98 Accord V6.
P1129 & P0505
Engine surges erratically in Park and Neutral. Sometimes it surges, sometimes it holds. On top of that, my car propels itself forward in any drive gear or reverse. I've cleaned and replaced the IAC vales and the TPS sensor. Kind of at my wits end right now. I've heard that replacing a manifold or the alternator would eliminate the problem.
MyEj1Broke
Jan 10, 2014 08:09 AM
Nisif
Nov 26, 2011 07:22 PM
integra15
Jun 23, 2010 02:30 PM
BOOSTED_JDM_DB8
Feb 3, 2006 01:01 AM
stump7117
Mar 27, 2005 09:06 PM
