1994 Honda accord EX wont go over 4000 rpms
Old Apr 10, 2018 | 12:43 PM
JonsWagon's Avatar
Default 1994 Honda accord EX wont go over 4000 rpms
I'm having a problem where my rev range is limited to 4k. When i hit 4000 rpm it sounds like it sputters and breaks up. I have replaced the oil pressure sensor, distributor, checked all the injectors and checked for any leaks at the intake manifold and throttle body. No trouble codes or CEL codes. Automatic transmission
Old Apr 10, 2018 | 07:23 PM
Mdxwithspeed1's Avatar
Default Re: 1994 Honda accord EX wont go over 4000 rpms
You may have a restriction in the exhaust system, if you know how to test a cat with a infrared thermometer then go for it, it's simple.
Old Apr 11, 2018 | 12:11 AM
holmesnmanny's Avatar
you can try removing the oxygen sensor from the downpipe to check if the cat is clogged, if it runs better than the issue is the cat is clogged
if it still runs bad then it's possible the distributor is bad
Old Apr 11, 2018 | 02:49 PM
JonsWagon's Avatar
ill check out the catalytic converter and see if it is the issue. i appreciate the help
Old Apr 11, 2018 | 02:54 PM
Suma's Avatar
If you had the distributor off, make sure it isn’t 180 out of phase.
They say say the offset keeps it only going in the correct way. I can tell you it will go in the wrong way and act like a governor.
MAD_MIKE's Avatar
MM Gruppe B
Usually if there is an engine problem 'limp mode' the engine will not rev past 3K.
If there is a VTEC problem, you might be able to get it up to 4K, but usually it will not get past 3500.(check you have full oil)
If the tach is faulty, you could actually be hitting actual redline and the tach is just reading wrong. 65MPH with the factory trans should be ~2800rpm. If it reads lower then the Tach is probably wrong.
Old Apr 13, 2018 | 04:25 PM
JonsWagon's Avatar
I found that one of my injectors is bad so im going to clean it out. Earlier in the week i used Carb-medic because i thought it was fuel related and sure enough my rpms now go to 4750
JonsWagon
May 2, 2018 04:27 PM
Bourne19D
Dec 10, 2014 11:28 PM
EJ Rocket
May 24, 2013 07:33 AM
andrewoso28
Aug 12, 2011 05:09 PM
StockTeg
Mar 21, 2003 09:21 PM
