Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
Hiding wire harness and brake lines around front post?
Old Apr 9, 2018 | 07:00 PM
bloodkaiser's Avatar
Default Hiding wire harness and brake lines around front post?
Have looked around everywhere and can't seem to find a way to hide the harness going upto the battery box. Or the brake cables. Seen a lot of pictures people got nothing showing coming up to the battery box.
Any help would apretiate it!
Old Apr 13, 2018 | 10:35 AM
sTol2m's Avatar
Default Re: Hidding wire harness and brake lines around front post?
Hello, in order to hide the harness you will need a front frame cover. This goes directly behind the front wheel.
They cost about $35 on ebay and they bolt on. Next, you need to drill a hole in the frame (that will be covered
by the battery box) about 11inches +/- going up from the gas tank (just below black fuel/signal relay box). Put a gromet
in the hole so the frame doesn't cut the harness. Run the harness through the hole and down the front of the frame
(frame cover will hide it) and feed it under or beside the gas tank.
As for the throttle and brake cables, drill 2 holes on the upper side of the frame (to the side of first hole, but around the corner).
Feed the cables through the holes and down the front of the frame (frame cover will hide these also) and feed it beside the gas tank.
Hope this helps...
Old Apr 16, 2018 | 11:09 AM
sTol2m's Avatar
Found a few pictures to use as an example.
vtecjunkiie631
Jan 2, 2024 04:58 PM
b18 type r
Jan 31, 2011 01:29 PM
jdmdohcek98
Appearance Build Threads
Oct 24, 2009 03:52 PM
skUnK2jdm
Mar 10, 2007 09:26 AM
All_Motor_CRX
Apr 16, 2006 10:49 AM
