1991 Honda Civic ED6 driver side low beam not working
Hey guys,
So ive done about almost whatever i can to fix this issue. Ive been on the forums for about a couple hours but i cannot understand what to do first. My driver side low beam does not work. The guy who i bought the ed6 from had some ebay HID lights on there. The passenger side is fine. High beams and other lights work perfectly fine. I purchased new bulbs and checked the fuses, the plugs and everything seems fine. What should i do and how? Im not a smart electrician so let me know what i should check out or do in order to get it fixed. Thank you!
Unplug the harness from the lights. Probe the harness side with the low beams on to see if you have good voltage. If you don't have voltage, then you need to work backwards on the harness to see where you may have a open circuit. If you do have good voltage, then you need to check your circuit ground and/or take a closer look at the lamp assembly. This is where a electrical schematic for your car will come in handy.
