Need quick answer- 91 integra
Old Apr 7, 2018 | 04:17 PM
Steezy_Da9's Avatar
Default Need quick answer- 91 integra
Sup fam, so long story short i replaced my cam shaft seal and the 2 bolts that hold down the bearing cap snapped off..is this the end of the world? Or its not a big deal?
Old Apr 7, 2018 | 04:19 PM
Steezy_Da9's Avatar
Default Re: Need quick answer- 91 integra
The 2 bolts on The ex bearing cap snapped
Old Apr 7, 2018 | 06:48 PM
SpiderX1016's Avatar
If your lucky and it didn't snap clean off. Maybe you can take the cap off and vice grip it out. If not then have you or have someone extract it or drill it out.
Either way it'll eventually start leaking again if not taken care of.
Old Apr 7, 2018 | 07:00 PM
GIZZ - EXV's Avatar
Loved
Did you break the 2 under the valve cover? or outside of it? I think id be more concerned if the ones under the vc broke. It's not the end of the world but I'd still try to fix it.
Those little bolts should come out pretty easy. hopefully it snapped above the deck, it now if try a tiny punch before a reverse drill bit.
Old Apr 7, 2018 | 07:27 PM
Steezy_Da9's Avatar
Yeah the ones under the valve cover both snapped at mid bolt so half of the bolt is still in the hole threaded mid way the hole if that makes sense? Im not lucky cuz they didnt snap at the head of the bolt. There deep in there. Thats why im concerned
Old Apr 7, 2018 | 07:30 PM
Steezy_Da9's Avatar
Yeah there clean off but at mid bolt so the other half is still in the head deep in the whole. I have no clue how to remove it
Snackman508
16
May 23, 2009 04:40 PM
PatrickGSR94
Nov 15, 2008 05:40 PM
a1320addict
May 26, 2006 06:26 PM
TeamTooQuick
May 18, 2002 08:18 AM
MrSmith
Jul 21, 2001 02:33 AM
