Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
P0122 & P0107 lost signals after shifting to first gear
Old Apr 4, 2018 | 02:56 PM
assismarquis's Avatar
Icon3 P0122 & P0107 lost signals after shifting to first gear
Hi all,
I have a Honda Accord 2004 LX manual transmission. Currently I am trying to solved these two codes, P0122 & P0107. I have already cleaned Throttle body and replaced both sensors, TPS and MAP. I adjusted the TPS to the right position with reading 0.5V when throttle fully closed and 4.5V when throttle fully open.
The car starts fine with no problems. The Live Data reading and voltage reading are good when car in idle. When I shifted the gears to first gear, I lost both TPS and MAP signals. Live Data shows 0 and volt meter shows 0 too. That means I don't have electricity going through both sensors when I shift to first gear.
Have anyone encountered this problem before? How do I trouble shoot further to figure out where is the root cause of these problems?
Thanks for your time.
Update:
Found out how to trouble shoot this problem on my service manual. DTC P0107, P0122, and P0452 indicated at the same time. Basically I need to check for continuity between body ground and ECM/PCM connector terminals A20, A21, and E5 individually.
Old Apr 5, 2018 | 11:00 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: P0122 & P0107 lost signals after shifting to first gear
Measure the 5v reference on the TPS.
1 of the wires should read 4.5-4.9v at all times. (Imot sure which off the top of my head)
Old Mar 17, 2019 | 03:16 PM
turnert3's Avatar
Originally Posted by assismarquis
Hi all,
Update:
Having exact same problem. Wondering if you figured it out?
Old Mar 17, 2019 | 03:27 PM
Good thing that I took notes.
Took me about a month to figure it out.
Code: P0452, P0122, P0107
Solution: EMC/PCM Idle Learn Procedure. 11-316
When: replace ECM/PCM
or reset EMC/PCM
or update ECM/ PCM
or Replace or clean the throttle body ( I did this)
Old Mar 17, 2019 | 03:32 PM
turnert3's Avatar
or reset EMC/PCM
or update ECM/ PCM
is this where you rev it to 3000 rpm till fans kick on then let it idle for 5 mins?
Old Mar 17, 2019 | 03:40 PM
Yes.
Old Mar 17, 2019 | 03:41 PM
turnert3's Avatar
Yes.
awesome! Thanks for the quick replies! If this works I’ll send you a check lol
Old Mar 17, 2019 | 03:42 PM
Send me some bitcoins please :D
skuded
Engine Management and Tuning
11
Dec 15, 2010 02:07 PM
ComeOnKip
16
Sep 27, 2007 09:34 AM
ludedude00
Mar 14, 2005 04:31 PM
