Burning Oil
Old Apr 3, 2018 | 03:31 PM
91 Wagon's Avatar
Default Burning Oil
Car is a 98 accord 4cyl. Almost 200k miles.
I replaced the PCV valve and the plugs
I'm burning a quart every 500 miles. I don't understand why.
Compression came back at 150, 150, 145, 152.
Nothing I would worry about...
I'm not leaking any oil, what's the deal!?!
There was also no oil on my plugs.
Old Apr 3, 2018 | 04:58 PM
holmesnmanny's Avatar
Default Re: Burning Oil
could be the valve seals, do you have a lot of smoke on wot pulls ?
Old Apr 4, 2018 | 03:56 AM
91 Wagon's Avatar
I don't WOT, but I could give a try.
Old Apr 4, 2018 | 04:41 AM
When you floor it, do you get a bunch of blue smoke ?
Old Apr 4, 2018 | 08:48 AM
91 Wagon's Avatar
I know what you mean lol. I'll get back to you.
Old Apr 4, 2018 | 01:17 PM
91 Wagon's Avatar
No smoke under WOT. or anytime for that matter..
Old Apr 4, 2018 | 02:17 PM
if no oil in the coolant i would still replace the valve seals but i think you got a leak somehow
Old Apr 4, 2018 | 05:07 PM
91 Wagon's Avatar
Coolant levels are good and all coolant. When I changed the plugs I didn't even have any oil on the boots...
ill have to have the girlfriend follow me to make sure that it's not smoking.
Any links to a write up of the valve seal change?
Old Apr 4, 2018 | 06:27 PM
there are how-to's on youtube for using this tool
https://www.amazon.com/gp/product/B000P0ZJIS/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B000P0ZJIS/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
you will need need the
Amazon Amazon
with an air compressor and then put each cylinder at tdc and
https://www.amazon.com/gp/product/B016JRBZRY/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B016JRBZRY/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
this tool to use to remove each seal and to install
Old Apr 6, 2018 | 03:34 AM
91 Wagon's Avatar
Good info, thanks!
I stopped by the local Honda performance shop and they tell me it's an f series, it's going to burn oil because of the coating they use on the cylinder walls burns off.
hmmm.
cjprelude
Mar 7, 2015 05:45 PM
emosun
Feb 26, 2010 05:29 AM
Jax4gencivic
May 4, 2006 07:59 AM
preludeguy_92
Jun 25, 2005 11:39 AM
westsidejdmyo
Dec 26, 2003 04:23 PM
