95 civic manual trans issues
Hello ht so like the title says. I have a 95 civic with a d15b motor, a few days ago i was waiting to back out of my driveway when there was a thunk noise. I was in gear with clutch pressed all the way in. I out the car in neutral and tried reverse again. The trans grinded like the clutch was not pressed all the way. I got it into reverse and drove to work, after the thunk noise it is very hard to shift gears while motor is running. If the motor os off it will go into any gear no problem. I relpaced the master and slave cylinder today as well as put a new clutch in as well. It is still having the same issue. Also there is alot of free play in the clutch pedal after the thunk noise. Any ideas?
the clutch was replaced about 2 yrs ago wjen the motor was swapped in, ornatleast thats what. The shop told me, however it looked like the same clutch i jad put in abniur 3 yrs ago. However i just put a new clutch in last night and itnwas a autozone clutch. Local part store chain
