H22a4 Anyone know where this part goes?
Old Mar 28, 2018 | 10:56 PM
Prelude Type O's Avatar
Default H22a4 Anyone know where this part goes?
Took apart an h22 and a buddy wanted to know where this part comes from. Anyone got a general idea? Cylinder head or block?
Old Mar 28, 2018 | 11:38 PM
Default Re: H22a4 Anyone know where this part goes?
Bump
Old Mar 29, 2018 | 03:18 PM
Found out it's a balance shaft retainer. I'm certain this goes into the block.
Old Mar 30, 2018 | 12:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes, it is the front balance shaft retaining clip. It is installed on the engine block under the oil pump between the block and the retaining ring of the front balance shaft.
Old Mar 31, 2018 | 01:39 PM
Icon5 Re: H22a4 Anyone know where this part goes?
There is no way of installing this back in without taking off the girdle and crank correct?
Old Mar 31, 2018 | 08:48 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The crankshaft and main girdle can stay in place... you will have to remove the oil pan, pick up and oil pump from the front of the block in order to install the piece.
Old Apr 1, 2018 | 06:42 PM
Sweet. Saves us some time. Thx
Old Apr 2, 2018 | 02:05 PM
holmesnmanny's Avatar
I'm trying to remember on my car without going back in, doesn't this thing just bolt up to the oil pump on the outside ? You can't just pull the two bolts and it comes right off without taking off the oil pump ? I feel like that's the way it was on my h22a but perhaps the a4 is different.
Old Apr 2, 2018 | 09:48 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Nope. The front balance shaft seal is on the oil pump housing... the shaft retaining bracket goes inside. You must remove the oil pump assembly to access the location for this retaining bracket.
Old Apr 2, 2018 | 11:10 PM
Ok, now Im curious if mine is the same or not. That really sucks they gotta take all that off to get to it.
Old Apr 5, 2018 | 10:01 AM
Could this be a reason for bouncing idling upon start up of a fresh built engine? Nvm probably just needs a tune
usdmftw
Apr 16, 2011 11:02 AM
KleenL
Dec 27, 2007 02:17 PM
mo0cow
Oct 26, 2005 04:36 AM
hotintegranights
Jun 19, 2004 10:11 AM
ludesleep
Jul 22, 2003 07:58 PM
