how do i tune 98 base prelude
Old Mar 28, 2018 | 04:40 PM
baselude98's Avatar
Default how do i tune 98 base prelude
i have a 1998 honda prelude base model and i want to get it tune but dont know what i need to do it..
Old Mar 29, 2018 | 04:47 PM
kve777's Avatar
Default Re: how do i tune 98 base prelude
What are your performance goals?
Old Mar 29, 2018 | 04:52 PM
baselude98's Avatar
It's my daily driver but I don't know if I can use my Ecu or do I need to get an obd1 jumper. I'm looking to build a daily driver but also fast as heck
Old Mar 29, 2018 | 05:06 PM
kve777's Avatar
How many miles on it?
Old Mar 29, 2018 | 05:07 PM
baselude98's Avatar
Alot lol 200xxx
Old Mar 29, 2018 | 05:20 PM
kve777's Avatar
A 200K mile engine isn't going to like "fast as heck" very much. Neither is the trans. Maybe you should buy a JDM engine and trans, rebuild them with some high performance parts, and drop them in after you upgrade your brakes and suspension. To go "fast as heck" safely will cost $$$. Maybe $10K. Trying to get more power out of your existing drivetrain will likely kill it in short order. If you just do regular maintenance, change the oil, put in new plugs, wires, cap, rotor, PCV valve, etc, plus clean the throttle body, do a full Sea-Foam treatment, change your trans fluid, solve any CEL issues, you will likely be surprised how well it will perform without mods.
Old Mar 29, 2018 | 05:36 PM
baselude98's Avatar
I know 200xxx is Alot and I planned on getting a h22a I've done all those things u said I already have header back exhaust tein advance super street suspensionand drilled slotted brakes new wires plugs distributor just did oil change trans fluid change. I just bought the car 3 weeks ago. And did all of that. And it's not gonna be 10k to do what I want. I just rebuilt an 02 rsx type s from the ground up completely rebuilt k20a2 got it tuned on Kpro and put tein electronic damper control with tein coilovers all for 3k
Old Mar 29, 2018 | 06:00 PM
kve777's Avatar
You should have mentioned this in your original post.
Old Mar 29, 2018 | 06:03 PM
kve777's Avatar
Sounds like you should go with a chipped OBD1 ECU if you want more, cheap power.
Old Mar 29, 2018 | 06:17 PM
baselude98's Avatar
Ok sorry bout that. But that's where I was getting I'm not sure which Ecu I should get or does any obd1 vtec Ecu work?
Old Mar 29, 2018 | 06:41 PM
kve777's Avatar
I found this over at PreludeOnline.Com:
1. It is the obd1 gsr ecu that is compatible with the hondata s100 and s300 systems. That is the one you would need to buy for the prelude 97-01.
2. you will need a obd2a to obd1 harness (correct me if i'm wrong) to get the obd1 to fit your prelude.
3. You do not want to put in the gsr ecu unless you are going with a hondata system, because it is costly and dangerous without a tune.
4. You will, unfortunately, lose atts when you switch the ecu.
Old Mar 29, 2018 | 06:49 PM
baselude98's Avatar
What's atts?
Old Mar 29, 2018 | 08:40 PM
TimiK's Avatar
10 Year Member
Stock car doenst need a tune. First build your engine and then start thinking tune.
Anyway you need OBD1 swap there (harness+ecu) - then it depends how youre going to build your engine that do you need proper engine management like Hondata or just chipped ecu
If youre going to build your engine all over again dont bother to get swap engine if youre going to new everything anyway - waste of money (unless your blocks cylinder walls are beyond saving)
What's atts?
SH's transmission's electrical differential which disables itself and become just dead weight if you change the ecu there
So basicly you cannot tune SH
Old Mar 29, 2018 | 08:54 PM
baselude98's Avatar
Ok I do plan on rebuilding motor do you have a certain brand u would recommend me using for like the pistons and bearings and all? Thanks for all your help! I'm glad I got the base model I was choosing between the base and sh model.
Old Mar 29, 2018 | 09:28 PM
TimiK's Avatar
10 Year Member
First you need to get your block checked by some machine shop - if you need to hone cylinder walls you might need oversize pistons so dont do that mistake that you buy pistons blindly.
Many people (like me) are using Type S pistons (Uyuni Sales | eBay Stores) and for bearings OEM or ACL etc (see what your machine shop says)
If you sleeve your block you have more options but its of course also more expensive but with stock block your choices are ONLY: JDM Type S or Mahle gold pistons
Do some kind of plan what parts youre going to need (cams/intake manifold/custom exhaust?) - what power goals you have and so on
Old Mar 30, 2018 | 06:37 AM
baselude98's Avatar
If I rebuild my block and use type s pistons would they hold boost? I don't mean Alot maybe like 8-10lbs
Old Mar 30, 2018 | 06:46 AM
snobordboy's Avatar
Moderator
Sounds like a bunch of questions that you could probably get a great answer from whoever tuned your Kpro on the RSX.....
Old Mar 30, 2018 | 07:35 AM
TimiK's Avatar
10 Year Member
Na and boost routes are totally different
Old Mar 31, 2018 | 05:14 AM
motoxxxman's Avatar
x2
I'd be finding a tuner and asking the tuner all of these questions before anything/anyone else.
KalD
Jun 21, 2014 07:36 AM
How boutthat
Oct 23, 2007 12:03 PM
Unlimitationz
Apr 1, 2005 06:25 PM
damonk
Jun 10, 2004 04:36 PM
IRFertl
Mar 29, 2004 10:43 PM
