Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Is it possible to remove vtec from the ecu
Old Mar 28, 2018 | 11:13 AM
Joshua_Missey's Avatar
Default Is it possible to remove vtec from the ecu
I bought this 2003 civic ex about 6 months ago and its been in limp mode since i got it thinking its probably just the vtec solenoid or something like that so yes I have been driving daily in a car stuck in limp mode. I found out about a month ago when I went to go change the vtec solenoid that the previous owner had swapped a non vtec motor into it and just put a vtec solenoid on the back. The car is an ex so it had a vtec motor but now it doesn't so the ecu freaks out and puts it into a limp mode is there any way that I could remove the vtec from the current ecu or just get a non vtec ecu because I don't feel like changing the head to a vtec head. Thanks.
Old Mar 29, 2018 | 10:02 PM
Bert209's Avatar
Default Re: Is it possible to remove vtec from the ecu
Im more surprised the theres a spot to mount the solenoid on a non v head. If you have a non v engine and have a v ecu it wont work, you need the non v ecu to work and just remove the solenoid, dont cut the wires going to the solenoid, just tuck them away incase you get urge for vtec yo. The problem i see though is finding the right ecu with all the options of an ex, aka moon roof, cruise control, alarm, abs, tach, as far as i know the lx models dont come well equipped, my choice would be get the v head and save yourself some headaches, your block is a a2 right?
Old Mar 30, 2018 | 02:20 PM
Yeah it's an a2 that's what I was worried about with the of cry thanks.
Old Mar 30, 2018 | 02:21 PM
OF ECU* not cry lol
Originally Posted by Joshua_Missey
OF ECU* not cry lol
LX*
Old Mar 30, 2018 | 02:42 PM
holmesnmanny's Avatar
take a picture of the head and the solenoid attached to the head
Old Jun 27, 2018 | 06:17 PM
gabriel shaw's Avatar
Did you solve this problem I have the same I had the same problem with my civic tried a new non vtec ECU car didn't want to start without giving gas
Old Jun 28, 2018 | 12:35 PM
thisguyaves's Avatar
Block stamp? If you have a spot to bolt on a vtec solenoid, it should have vtec. Or remove the valve cover and know for sure
heflin94eg
Engine Management and Tuning
Dec 4, 2012 05:19 PM
vtechaccord
Mar 14, 2011 03:03 PM
SEgrnTeg
Apr 8, 2008 06:05 PM
bigsubs
Jun 15, 2007 08:42 PM
