IACV Connections
Old Mar 28, 2018 | 08:52 AM
nohow's Avatar
Default IACV Connections
Honda Smart People,
I have a 1998 Honda Accord with an F23A engine and a 5 speed transmission.
When my idle started to act up, I took a look at the IACV and saw that there was what appeared to be a vacuum hose dangling off of it. After my “Ah Ha!” moment, I realized that I wasn’t sure where this connection is supposed to be made.
Long story short the coolant hoses are connected to the IACV but the vacuum hose connected to the valve is not.
Any help would be appreciated!
Old Apr 3, 2018 | 10:10 AM
nohow's Avatar
Default Re: IACV Connections
I took another look at the lose hose connected to my IACV and it appears to be about 6 inches long. I felt around the area for anything that might be within reach of the hose but, I couldn't seem to find anything.
I have to be missing something.
Thanks!
Old Apr 18, 2018 | 11:49 AM
nohow's Avatar
After some extended asking around, it appears that the hose in question doesn't seem to server a purpose other than to provide a source of air to the IACV valve. It being not connected to anything hasn't effected the engine or idle performance one way or another.
This issue was originally encountered while we were looking for the source of a surging idle in my 1998 Honda Accord LX. This problem turned out to have been caused by a flap that was stuck in the IACV. We tested this by putting a finger over the port to the IACV in the front of the throttle body (I attempted to add the image below). Once the flap was cleaned up and lubricated, we reinstalled it and the idle ran smoothly with no surging. At first start it went to about 11,000 rpm and then went to 750 rpm after the engine came up to temp just as it should have.
I know this post has been read a number of times so, I hope this information might help someone else.
Old Aug 17, 2025 | 06:40 PM
adelara's Avatar
10 Year Member
oh holy mother of god... thank you. This has been very helpful.
I've been trying to find where to connect that stinking hose for more than 3 hours and nothing came close... You nailed it - when I removed the top of the intake manifold, I did not pay enough attention to see that hose had "no other side connection". Ye p, that is the damn hose: about 6-7 inches, back coming out of the IACV, L-shaped, turns toward the driver side. I had a hard time believing it goes nowhere, but you confirmed it.
My '98 Accord has a rough idling, almost chokes on red light, lots of hesitation when getting going from stops - my "old faithful mechanic" could not figure this out... I think he was not very interested as after a few months he retired... anyway. Thanks again.
Here's a pic out of my useless "feel around the back desperation".... hopefully will help yet someone else.
Choppin
Aug 20, 2025 05:51 PM
redryan243
Nov 14, 2013 10:26 PM
crfr230
Apr 26, 2007 06:31 PM
YoungKadafi
Apr 1, 2007 09:16 AM
XstouterX
Nov 11, 2005 11:30 PM
