Gasoline in oil please help
Old Mar 24, 2018 | 10:52 AM
jspinelli8's Avatar
Default Gasoline in oil please help
i was draining the oil and i didnt think it looked right so i took off the valve cover and noticed that the oil smelled strongly of gasoline. The oil looks really light. Just some background on the motor it was sitting for about 8 months and i just drove it around a few miles before i drained it to check the oil for the first time. I dont know what the cause is or how to fix it
Old Mar 27, 2018 | 10:33 AM
thewrai6th's Avatar
Default Re: Gasoline in oil please help
The only way I can imagine you getting gas in your oil would be if your injectors got stuck open, you parked on a hill, and gas just drained into the cylinders while it sat for months. Or maybe it dumped gas into one cylinder that is not firing when you went on a test drive. I'd just do an oil change and move on, provided the engine runs smoothly.
Old Mar 28, 2018 | 11:26 AM
jspinelli8's Avatar
Thanks
Old Mar 29, 2018 | 04:34 PM
kve777's Avatar
You might need to re-seat your rings after sitting. A few drops of Marvel Mystery Oil in the spark plug holes, crank for a minute with no plugs to disperse oil, let sit over night. Put in fresh plugs, start, let idle for about 15 minutes. Expect a bit of white smoke from burning MMO. Change your oil again.
AliciaKat23
Mar 30, 2013 09:25 PM
xluben
Feb 10, 2007 04:38 PM
k_lude
Jan 7, 2007 11:40 AM
Nextelbuddy
May 30, 2003 07:50 AM
94thundergrey
Nov 12, 2002 12:55 PM
