1989 civic stuck in Park
Old Mar 23, 2018 | 12:33 PM
Lindsay Horton's Avatar
Default 1989 civic stuck in Park
1989 civic stuck in park.. Would appreciate any advise.. Can not find solenoid on gear box.. Brake light do come on with foot on pedal .. Please help thanks in advance
Old Mar 23, 2018 | 01:28 PM
MyAcc0rd's Avatar
Default Re: 1989 civic stuck in Park
Mayyyybe a bad brake light switch.
Old Mar 23, 2018 | 10:34 PM
Marcos Barrios's Avatar
does it stay in park even if you use your key or screw driver on the auto shifter to get it out of park
Old Mar 24, 2018 | 03:01 AM
I could not find a tab or ?? On console to release brake as I saw on video.. I have taken console off transmission position switch and attempted to take out of park.. The handle is off change stick when pushing but on top down appears to work but cant take out of park.. All looks right ..Possible cable lock as well or us. Thank you
Old Mar 24, 2018 | 01:09 PM
this isnt a ef civic shifter but on here you can see what im talking about
you remove the little plastic cover and then with a key or screw driver u just push down and it should go into gear
theres also another way to do this and thats disconnecting the battery
and then going into the car
put the key in as if to start the car and get the shifter out of park
let me know if any of the two options work for you
Old Mar 24, 2018 | 05:21 PM
Hi Marcos unfortuantly both those ideas do not work .. The console has not got that plug and looks a lot different is the Honda console tho
Old Mar 25, 2018 | 05:20 PM
ok if non of the other ideas are working
then im guessing theres just somthing wrongwith the shifter itself
sounds like your going to have to take it apart and see why its jammed
good thing is that it can be taken apart with just a philips screw driver and a 10mm socket
take it apart and post some pictures
Old Mar 25, 2018 | 06:58 PM
~sp33~'s Avatar
EFB055
His picture is different, but the idea is the same. There is a hole to the right of the 'P' location of your shifter for you to stick your key in. This should allow you to move the shifter out of park.
Angela Gray
Oct 24, 2012 05:08 PM
Jedimiah
Jun 8, 2007 11:04 PM
NYCsnowman
Jan 24, 2006 01:13 PM
bobobram
Aug 9, 2005 09:25 PM
maxburnout
Nov 30, 2004 04:00 PM
