Engine Starts Screeching at Low RPM and Continues When RPM is Raised
I have a 2003 Civic D17A1 manual, 202k.
I recently rebuilt my cylinder head and replaced all timing components (the timing belt broke), and replaced a bunch of sensors, vacuum hoses, PCV and IACV, etc. I did the Idle relearn procedure as well.
Now my car idles at around 750 RPM when there is no engine strain, but, when additional engine strain is put on (anything from turning on heat, headlights, defogger, or even cranking the wheel all the way to the side), the engine nearly stalls for a second and a squeaking noise appears. This squeaking noise continues even when the strain is taken off of the engine and the RPMs rise such as when I start driving (the screech is higher pitched the higher the RPMs). It only goes away once I have been driving for long enough (about 5 min without returning to idle, and the pitch of the screeching gets higher) and then turn off all additional strains on the engine. The noise does not occur even with all components on as long as they are turned on while driving and the car is not allowed to return to idle, but will occur if the car goes to idle with the strains on it. It doesn't matter if it is idling in neutral or just with clutch depressed, it has the same results. The screeching noise sounds like the combination of a squeaky belt and the sound it makes when you try to accelerate with the gear shift mostly in first (the gear grinding noise). It is really confusing me as to why this noise occurs or what is even causing it. It only seems to occur after I did the repairs, although this is my first winter with the car. Also, the noise does not appear when the car is warming up and is over 1k RPM.
Any help or insight would be greatly appreciated!
grab the power steering belt with your thumb and index finger, twist it, it should only twist about 90 degrees, if it's twisting too much then tighten it to spec
do the same with the alternator belt but at the longest side of the belt, in the middle of that side
if both of these belts are good then it's likely the timing belt is the culprit
hondaStarter
Jan 14, 2011 03:22 PM
Zumo
Feb 16, 2007 10:45 PM
Ideal R
Dec 28, 2001 11:37 AM
