Cluster questions please help
Old Mar 17, 2018 | 03:34 PM
Jesse6219's Avatar
Default Cluster questions please help
I am looking to install a 97 civic cluster into my 89 civic hatchback im currently runnin a d16z6 with a y8 manual transmission with a ry wire harness everything works well except the cable speedo but i havent had any luck at all finding a write up about how to do this swap thanks in advance and i apologize for such an unorthodox question
Old Mar 17, 2018 | 03:40 PM
Marcos Barrios's Avatar
Default Re: Cluster questions please help
so your looking for a write up on how to install the 97 cluster
and also on how to do the wiring
into your 89 civic
Old Mar 17, 2018 | 03:47 PM
Jesse6219's Avatar
Looking for how to install and wire the 97 cluster into the 89 hatchback so itll work properly
Old Mar 17, 2018 | 05:26 PM
acmoc's Avatar
I think you have to find the wiring diagrams for both and splice the corresponding connections together
The speedo cables should just plug in I think.
Old Mar 18, 2018 | 03:44 AM
Jesse6219's Avatar
Ive found the pinout on the 89 but all i find looking for the 97 pinout is for integra idk why google does that but it does and all the old post of ek cluster in an ef are either gone or the pics want load to make sure what there doing
Old Mar 18, 2018 | 05:51 PM
acmoc's Avatar
Yea, it's gonna be hard due to the photobucket debacle.
Old Mar 18, 2018 | 06:46 PM
~sp33~'s Avatar
EFB055
What cable? The Y8 box should have the VSS in place, your rywire harness should have a plug for the VSS, and your EK cluster will be looking for the signal from it. You need to connect the cluster to the wire on your rywire harness.
Download the EK workshop manual, it has wiring diagrams in the back of it that you can use to match. If you can't find a download link, PM me your email address and i'll send it to you.
Old Mar 18, 2018 | 08:47 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Trace the circuit film on the back. I did this back in ‘04 to put in a GSR cluster.
Smo99
Aug 27, 2018 05:08 PM
SpeedDemonRex
Apr 13, 2013 06:25 PM
96 civic hatch
Aug 8, 2010 09:36 PM
