97 CRV overheating and radiator fan does not turn on by itself
Hi all - I have a 97 CRV that is overheating while standing still. The temp gauge will go up to 3/4 mark and the radiator fan will not turn on. I can turn the A/C on or heat at max and the temp starts dropping.
First I had to fix the temp gauge as that wasn't reading correctly. It is now reading correctly. Both fans turn on with the A/C. The radiator fan turns on when jumped at the connector. Upper and lower radiator hose gets hot. Coolant reservoir is filled to max.
I have replaced:
1. temp gauge sender (gauge wasn't reading right)
2. thermostat (thinking this was the gauge issue)
3. Radiator fan (it was seized)
4. Cooling fan fuse (under hood, I think the seized fan blew it)
5. Coolant/radiator fan switch (twice thinking I got a dud)
Is there anything else I should look into?
I have replaced:
crazyhouse2011
11
Mar 8, 2013 07:10 AM
deerman2701
Dec 13, 2012 07:25 PM
