filler rod for 6061 0.118 sheet intake manifold 5356 or 4043.
Old Mar 13, 2018 | 06:10 PM
RACEPAK's Avatar
Default filler rod for 6061 0.118 sheet intake manifold 5356 or 4043.
hey guys,
haven't been here in a while.
question to the experts if they are still here,
which filler rod do you recommend for welding a 6061 0.118 (3mm) sheet intake manifold.
i have 5356 and 4043.
i assumed 5356 is a better choice until i saw that 5356 isn't good for temperatures above 150F,
thanks alot!!!
Old Apr 10, 2018 | 02:37 PM
para pat's Avatar
Default Re: filler rod for 6061 0.118 sheet intake manifold 5356 or 4043.
reserve the 5356 for cast and anodized parts. stick to the 4043 for the 6000 series alloys
Old Apr 13, 2018 | 07:53 AM
850Fabrication's Avatar
I always use 5356. the end result and look with 5356 wire is superior to 4043 IMO. I reserve 4043 for cast and general welding/repair
Old Apr 13, 2018 | 11:28 AM
CODE4's Avatar
You need to match your filler wire selection to what you are doing. There is no end all be all filler rod solution. I have been using Maxal 4943 a bit more (read this article: http://www.fabricatingandmetalworkin...lsion-systems/).
5356 and 4043 both have their limitations. You need to ask if the part will see post weld anodizing, the weld joint's service temperature, etc.
Old Jul 22, 2018 | 04:04 PM
Wesley Lewis's Avatar
Use 4047 for it. It has twice as much silicon for flow and it's stronger than 4043 also.
LumpyTheGrumpyCamshaft
Welding / Fabrication
15
Aug 12, 2009 05:52 PM
autosport7
Nov 22, 2006 11:28 PM
Forrest Gump 9
Nov 19, 2005 07:59 AM
dnbruut
Aug 2, 2005 09:05 AM
