Honda S2000 Honda S2000
Need help raising height of s2k
Old Mar 10, 2018 | 07:13 PM
CHAMPwhteEK's Avatar
Default Need help raising height of s2k
so long story short I’m in the middle of adjusting the ride height of my s2k as the previous owner had it slammed. My problem that I’m running into is that once I loosen the lower spendel. When I try adjusting the height with the upper spendel it’s way to hard... I Un bolted the coil from the lower arm conection. Once I did that the coil was a lot easier to adjust. My problem now is that the lower arm won’t drop down any lower. Any help is appreciated!.
Old Jun 16, 2018 | 08:27 AM
talontsiawd's Avatar
Default Re: Need help raising height of s2k
I am just browsing as I recently acquired an S2000. I have put springs and coil overs on a lot of Honda's and a few RWD cars with multi-link suspension. I often use the factory scissor jack to drop the lower control arm when it fits, trying to get the bottom (or top) on the arm, the other side on something solid that does not move. If it fits (don't know how tight it is on an S2000), it saves a bunch of time and energy so it is a go to method for me.
Old Jun 16, 2018 | 09:58 PM
toyomatt84's Avatar
Sanji
If the anti-sway bar is still attached, that could be preventing the movement on the control arm.
mikej94civex
Dec 31, 2009 01:39 PM
si90rex
Welding / Fabrication
10
Mar 15, 2008 06:06 PM
RTW DC2R
Mar 13, 2007 05:22 PM
vtecths
Dec 10, 2004 08:23 PM
civicrr
17
Jul 7, 2002 09:04 PM
