H23 pistons with h22a1 crank and rods to lower compression for boost
Old Mar 10, 2018 | 08:08 AM
Jason Helton's Avatar
Icon3 H23 pistons with h22a1 crank and rods to lower compression for boost
Is it possible to combine H23a1 Pistons with H22a1 Crank and Rods and still have Head/Valve clearance? If so what would the compression ratio be considering this combination andthe lower stroke of the h22 crank? Current compression of h23a1 pistons is 9.8:1. With the lower stroke it should be reduced. This would be Good for Boost without having to payout the expense of resleeving for aftermarket pistons or using Mahle Gold series FRM compatible pistons. What are your thoughts?
Old Mar 10, 2018 | 09:00 PM
TimiK's Avatar
10 Year Member
Default Re: H23 pistons with h22a1 crank and rods to lower compression for boost
sleeving and aftermarket pistons are always more durable and reliable
you dont need super low compression for boost if your setup is right
Old Mar 11, 2018 | 01:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The material that stock pistons designed for FRM sleeves are created from is brittle... so lower compression or not, you are still going to be limited on how much power you can make by using stock type pistons.
Old Mar 12, 2018 | 09:56 AM
crazes's Avatar
Moderator
resleeve your block and purchase correct pistons for your rod to crank. saves plenty of headaches and less worries about frm sleeves
Old Mar 12, 2018 | 06:34 PM
snobordboy's Avatar
Moderator
This is the biggest deal with these engines and Boost/ Nitrous/ big power N/A. Most boost guys now are actually running 10+ compression with decent fuel and tuning, especially E85.
If you want to pull an engine apart, do it right the first time. Otherwise you are handicapping the engine so much that a well built N/A setup will be faster and more reliable.
seigisama
Engine Machining & Assembly
Aug 5, 2016 03:47 AM
Erickgonz20
Dec 6, 2015 10:25 PM
michaelprice83
Feb 16, 2011 05:56 PM
BlkChryKord
Nov 6, 2006 11:35 AM
EM2MoNsTeR
Sep 15, 2003 02:06 PM
