Honda CR-V & Element 2WD & 4WD Element & CR-V
B20 cambelt rear plastic cover touching cam pulleys?
Old Mar 9, 2018 | 01:33 PM
B20Zer's Avatar
Default B20 cambelt rear plastic cover touching cam pulleys?
I took off the valve cover on my CRV B20Z engine to check the valve clearance and I noticed whoever worked on the engine last must have refitted the rear/inner plastic cambelt cover incorrectly. The top edges are pushed into the cam pulley and the pulley has worn into the plastic, the lower part of the cover looks fine though, it seems the top part has caught on a lip or similar and wasn't properly seated when fitted.
Does anyone know why that would happen and if I can correct it without taking the cambelt and pulleys off?
And from what you can see does that cambelt look overly worn, it was supposedly replaced 40,000km ago
Pics:
Old Mar 9, 2018 | 06:35 PM
spider2k's Avatar
Default Re: B20 cambelt rear plastic cover touching cam pulleys?
it isnt in wrong, its just old and it warps. looks like whoever changed the timing belt didn't replace it.
Old Mar 10, 2018 | 01:22 AM
B20Zer's Avatar
Is that a common issue with these engines?
I've never seen that happen before and the only way that I can see it getting warped that much is due to incorrect fitment of the cover.
Old Mar 12, 2018 | 02:11 AM
B20Zer's Avatar
Anyone have experience with the cambelt covers warping on these engines?
Other than if the engine has been badly overheated I can't see why it would happen but I'm open to being corrected, it's only the tips right at the top that are bent in on mine, otherwise the covers are straight which is why I'm assuming fitment issues.
Old Mar 17, 2018 | 09:28 AM
B20Zer's Avatar
I pulled it all off and it's obviously warped due to heat, otherwise it's fine and I got my heatgun out and got it straight again.
Is there anyway to avoid the cover from getting warped?
I'm planning on applying RTV heat resistant silicone between the head and the cover where it's prone to warping and hopefully that'll help to keep it in place and not start bending away from the head again. Could I run into any issues doing that?
Old Mar 18, 2018 | 09:38 AM
spider2k's Avatar
i think it's an age thing too. anyone i've ever talked to and most timing belt/ water pump kit comes with all these plastic bits.
Old Mar 18, 2018 | 09:54 AM
B20Zer's Avatar
Thanks Spider2k
Old Mar 21, 2018 | 06:26 PM
spider2k's Avatar
Thanks Spider2k
sorry im not much help. i just trimmed mine back because i didnt want to take it all off.
Old Mar 22, 2018 | 02:45 AM
B20Zer's Avatar
Did you trim off the parts that were warped and bending into the belt/pulley?
Joey Mitchell
Jul 11, 2018 02:53 AM
B20Zer
14
Jan 20, 2018 07:06 AM
jaje
Nov 11, 2009 10:22 AM
B18 Dc4
Apr 22, 2009 07:01 AM
StewBme
Apr 8, 2004 08:31 AM
