Engine swap question.
Old Mar 3, 2018 | 06:21 PM
Chico. Pitzer.'s Avatar
Default Engine swap question.
So I'm new to this, but I was wanting to know what engine swap I should do...I have 1999 Honda Accord 2.3L vtec but I was considering an engine swap, but would like to know which one from some people who have the know how's... I've read some of the conversation on here and was pretty interested.
Old Mar 3, 2018 | 06:33 PM
94 accord typeR's Avatar
Default Re: Engine swap question.
Google search prelude h23 or dont waste ur time
Old Mar 3, 2018 | 06:36 PM
About how much money does it cost... I have a summer job making roughly 500 a week I'm only a sophomore so summer job is full time and school is Kroger's lol...chump change
Old Mar 3, 2018 | 06:45 PM
7 million plus tax lol save ur money h23 has 200 hp f23 has 145
Old Mar 3, 2018 | 06:46 PM
MAD_MIKE's Avatar
MM Gruppe B
Depends on where you live.
If emissions testing/BAR certification is done, you will have to stick with a H22 from a 99-01 Prelude.
H23 VTEC was never available in the US so it would not be a street legal swap.
Also you will want to swap out your transmission for the H22/H23 trans as the gearing matches the engines powerband vs the F23 transmission.
Old Mar 3, 2018 | 06:50 PM
Ok thank you, so after that what would be some aftermarket parts that aren't super hard. I've had a fare share of working on cars in my life but like I said only sophomore so not TOO EXPERIENCED
Well thank you very much
Old Mar 3, 2018 | 06:53 PM
MAD_MIKE's Avatar
MM Gruppe B
Check Honda Motors Online for engines/transmissions, and to get an idea on pricing.
Old Mar 3, 2018 | 06:54 PM
Ill probably just wait till later in my life when it's a project car instead of daily driver lol
Old Mar 3, 2018 | 07:05 PM
Would a aluminum pulley kit be worth buying?
Old Mar 3, 2018 | 10:57 PM
holmesnmanny's Avatar
the h23a vtec and f20b are both functionally the same as the h22a so it would be able to be bar'ed, it would have to be bar'ed as an h22a1 so it would need the usdm ecu and emissions
Old Mar 4, 2018 | 07:35 PM
MAD_MIKE's Avatar
MM Gruppe B
'Power Pulleys', usually an AL crank hub that replaces the factory harmonic damper, will just cause damage to the engine. Without a proper harmonic damper, there will be no way to control harmful vibrations caused by the moving components. Unorthodox Racing used to have a crank pulley that was just a pulley. Do not use that. Without a damper the engine will destroy itself.
ATI - The Dangers of Power Pulleys & Understanding the Harmonic Damper
ATI does make a AL shelled harmonic damper, but that's about ~$400. Worth it if you plan on building an engine.
H23 VTEC would awesome, but problem is it has 'H23' cast into the block.
Now a 'H22' VTEC with the H23 rotating assembly... although seems like a bit of work.
Old Mar 5, 2018 | 12:41 AM
it's a special kind of h23a engine specially made to be similar to the h22a
https://en.wikipedia.org/wiki/Honda_...H23A_DOHC_VTEC
H23A DOHC VTEC[edit]
In 1998, Honda of Japan produced a rare DOHC VTEC version of the H23A engine for use in Japan only. It has been factory modified with an internal oil passage in the H23A block to operate the VTEC solenoid in the H22A head. Having the same horsepower rating as the H22A engine but it has a lower redline of 7200rpms because it has a longer stroke than the H22A. The H23A DOHC VTEC has 87mm x 95mm (bore and stroke) and the H22A DOHC VTEC has 87mm x 90.7mm (bore and stroke). The H23A DOHC VTEC Engine is largest displacement in the H Series engines with a compression ratio of 10.6:1.
https://honda-tech.com/forums/honda-...tions-2341343/
https://www.ebay.com/itm/Jdm-Honda-A...JaKayE&vxp=mtr
Old Mar 6, 2018 | 12:08 PM
MAD_MIKE's Avatar
MM Gruppe B
I know the BlueTops, would probably be the only swap I would bother with. But here in CA, at least around here, the smog techs are fairly diligent in making sure everything is up to snuff.
Visually the H22 VTEC or H23(non VTEC) engine is legal. Show up with a H23 VTEC Blue Top, even using all the Prelude bits around it, may net you a fail.
d-lude
Feb 3, 2008 04:20 PM
team 15
11
Sep 2, 2007 02:07 PM
bbp2024
Dec 27, 2006 12:39 PM
Littleaccordman
Apr 20, 2004 09:39 AM
