knock sensor help
Old Mar 3, 2018 | 12:59 PM
jdmland69's Avatar
Default knock sensor help
i have a 2002 accord that came with the factory f23a1 and when i blew it up i replaced it with the jdm f23a ever since then i have been getting a knock sensor code, put a new knock sensor in and same thing code comes up wondering if anyone else has run into this issue, also surging at idle changed idle air control valve, checked for leaks and nothing still surges
Old Mar 3, 2018 | 06:36 PM
94 accord typeR's Avatar
Default Re: knock sensor help
Might need jdm ecu
Old Mar 4, 2018 | 05:33 AM
GhostAccord's Avatar
Did you do a compression test on the engine before installation? If not, I would start there.
Did you install new spark plugs and wires?
Are you using your F23 stock intake and exhaust manifolds or the JDM ones?
Is the Check engine light on? are there any other codes being triggered other than the knock sensor.
Old Mar 4, 2018 | 11:11 AM
jdmland69's Avatar
new plugs wires cap rotar, compression tested fine, using the jdm intake manifold and a aftermarket 4-1 header, only code in the system doesn't effect the drive ability at all and still hits vtec
accordlx5speed
Sep 10, 2014 05:27 PM
ek coupe
May 20, 2009 09:45 AM
SpoonFedEj8
Dec 23, 2008 03:11 PM
Sampsonite987
Mar 30, 2004 01:52 PM
stephenB!
Mar 12, 2004 06:33 AM
